I'm the owner of this sheet. I can reassure you that it was not intentional on my part.
Seems when first sharing the sheet I simply forgot to check the checkbox "Prevent editors from changing access and adding new people".
I saved a screenshot with a list of users who added permissions for themselves and maybe removed the public share afterwards.
The public share is now active again.
Thanks @Guillaume.
People also filter the sheet and leave it as filtered, which has caused confusion as some think the sheet has shrunken with the entries missing, which leads them to add themselves again. Would you please add to the top of the sheet (row 1, 2, etc.) the rules, tips, and warnings for this sheet, bolded in red. Thanks again.
I ended up buying:-
a cheap new Android phone (Nokia 1)
getting the Scan my Tesla app (more details in this thread Vendor - Scan My Tesla, a CANBUS reader for Android)
buying the correct cable from US (Tesla Diagnostic Port Adapter Cable (Model X/S post Sep-2015) 680201861183 | eBay) (price seems to have gone up)
and also buying an OBD2 bluetooth adaptor (https://www.ebay.co.uk/itm/OBDLink-LX-427201-ScanTool-Bluetooth-Professional-OBD-II-Scan-Tool-for-Andr/202462881688?ssPageName=STRK:MEBIDX:IT&_trksid=p2060353.m2749.l2649) - price has also gone up!
The correct port is under the main screen (not the OBD port on our RHD drivers side) - accessed by hard popping the cubby down.
Simples! Well not really but is once you have it all working and understand all the bits you need. The hardest thing in UK is getting the cable.
There is an Apple app (TM Spy?) though if you want to avoid the android route. Android Scan my Tesla has all the relevant info you could need and I like it.
I have gained 3 miles back with the most recent update I super charged but didn’t seem to pick up speed about the same. Will update in a few days if I get more mileage.
I ignored the joke and was just flagging the underlying claim. The bolded statements did not give all the details and so were incomplete, as they have to be to some extent to protect proprietary info, but still frustratingly so for some, but not BS.
Tesla also suggested I trade in my car (for $15,000) and buy a P100D for $150,000.
I was Supercharging once a day prior.
But, quite the contrary, i have 2 people here that Supercharge even more and have over 220,000 miles.
Sorry I'm late to the party here. 2013 P85 83K. Mine started a little different. My HV battery went bad 3 months ago and was replaced shortly before the update, At pickup it only showed 226 and I was told to the BMS needed to cycle a few times and it would go back to 250 or better (I have a nice clip). After many cycles, no change. I could go 210 miles at 300 wh/mi and hit motor reduction, with 10 miles left. 6 visits were terminated with texts like these;
Good morning this is Tedd with Tesla service. I have looked into your vehicle over your battery range concern. I am pleased to say that the High Voltage battery in your vehicle is healthy and shows no signs of issues or active alerts. The HV battery installed in your vehicle is a Tesla re-manufactured HV battery that is slightly better rated than the HV battery that was removed due to an internal failure. It is also important to remember that the rated range displayed next to the HV battery charge level on the center display is just an estimation and does not reflect the true range of the vehicle, as the end-of-drive conditions are based on real-time battery measurements of reducing battery power, rather than software estimates.No further diagnosis is needed and service visit not required at this time, would you like to cancel your appointment?
Further diagnosing into your concern along with your recent timestamp found no faults or active issues or alerts with your vehicle or the High Voltage battery system. The HV battery installed in your vehicle is a Tesla re-manufactured HV battery that is equal to or better than the HV battery removed. Both batteries have a build date of 2013 and the HV battery installed in the vehicle right now shows to be slightly better than the battery removed. For trying to calculate the batteries Kilowatt hour capacity it is important to remember that HV battery contains an energy reserve within the over all capacity. It also will use battery energy to maintain the 12v battery and run the vehicle's HVAC system to heat or cool the HV battery when the even when the vehicle is not in use. Your vehicle is working as designed for its age and usage. We can cancel this appointment at this time.
I finally got an appointment at a different SC that wasn't cancelled. On Friday the 9th of August, I went in and instead of blowing me off they fell all over themselves. Told me that they had this happen to someone else and would see if my pack had been limited to 90%. Surprise! My pack had this mysterious bug. They said they would call California and get me on a list. They said an update would come this week that I would not notice and it would be back to 248 or better. We'll see.
This may or may not be relevant to the BMS used by Tesla. We can all assume Tesla KNOWS this and have their BMS adjusted appropriately. The nominal degradation reported by thousands of actual users is much less than 10% even after 200,000 miles of use and more than 1,000 charge cycles.This is great read if you haven’t seen it before. Lots of details on charging Li-ion although it doesn’t get into mitigation strategies for older batteries.
Charging Lithium-Ion Batteries
$100 for that cable? There has to be DIY guide on how to make it that someone can link. The connectors are just few bucks, just need to know the pin connections on both sides.
Thanks. That is really helpful. I Presume the cables work for either Android or IOS.I ended up buying:-
currently P100D Raven is $106k even with FSD. Why would you say $150k which is obviously false? What else are you posting as fact which is not true?
This is astonishing!
@DJRas made a figurative comparison. His point was one car is more expensive than the other. You nitpick by accusing him he not telling the truth not only about the trivial price comparison but introducing doubts as to the trustfulness of his other posts. Amazing?
What's your agenda in this thread? How many miles have you lost?
Peace.
To me, the quoted article makes it clear that managing battery life is done in a variety of ways. It also talked about limiting “saturation” charge to increase battery life and reduce the chances of combustion. The methods are all over the map and using them is not indicative of if a defective battery. This type of research will be their exhibit A, and you will have to tell the judge why Tesla shouldn’t be able to limit peak battery charge on an older battery exhibiting stress while it’s OK for other battery users to do so. Using the “stole my battery capacity” argument isn’t going to fly when Tesla brings in battery experts (including outside experts) that actually know what they are talking about. Now, your other grievances are valid in my opinion. The abhorrent communications policy, used car advertised range, etc all need addressing. I’m still hoping Tesla has an epiphany and does right with you guys even if they could win the suit, similar to what Apple did. They have a chance to make some of you loyal customers but seem more interested in protecting their ego.This may or may not be relevant to the BMS used by Tesla. We can all assume Tesla KNOWS this and have their BMS adjusted appropriately. The nominal degradation reported by thousands of actual users is much less than 10% even after 200,000 miles of use and more than 1,000 charge cycles.
Again, this issue has NOTHING to do with degradation.
Tesla also suggested I trade in my car (for $15,000) and buy a P100D for $150,000. All because the battery is defective.
