The capped car still gives the old uncapped times(even when AC charging).Thanks. That chart definitely does not include the impacted cars. The funny part is the car told me it would take only 30 minutes.
The 60D -> 75D change doesn't have a reconfiguration to the charge battery graphic though. You know you're charging a capped 60D to less than 100% - it doesn't show the fraudulent 100% that capped 85 batteries are showing. But you're right they could easily hide that code, there is no open source auditing to validate everything is legitimate - and that's why we're here.
Thanks. So they forgot to manipulate that part of the code?
Or they beleive this is a temporary patch so they didn't bother to update other, related code. Don't have enough data to prove one or the other.
Bhz, at the risk of speaking for others, I think the question ha been answered in depth in this thread, and sensing a round of incoming sea lioning there's a hesitancy to engage in it.Again, what exactly precisely is the specific harm YOU are suffering right now from the update? Funny to see reluctance to simply and clearly answer the simple question.
They pushed 2019.8.3 to my unsupported / salvage titled car (from 2018.50.6), which seemed odd as the car had not been pushed any prior updates from Tesla since marked as salvage. I accepted the update, but that one also included the bug that broke max battery power / launch mode. 2019.16.2 fixed that bug, but then this whole mess started with 2019.16.1.1, so instead of rolling the dice on the range loss game, I rolled it back to 2019.4.2 to correct that issue and blocked Tesla's firmware update domain.Again what about the black listed and salvage cars that don't get updated? Are they going to make an exception and update those cars?
How did you do that?They pushed 2019.8.3 to my unsupported / salvage titled car (from 2018.50.6), which seemed odd as the car had not been pushed any prior updates from Tesla since marked as salvage. I accepted the update, but that one also included the bug that broke max battery power / launch mode. 2019.16.2 fixed that bug, but then this whole mess started with 2019.16.1.1, so instead of rolling the dice on the range loss game, I rolled it back to 2019.4.2 to correct that issue and blocked Tesla's firmware update domain.
I would also like to know how you rolled the software back. Has tesla ever before now updated a non supported salvage car? If not then what does that mean if they updated your salvage car?How did you do that?
Dendrites were discussed here previously. This article helped me better understand what they are and how they are formed. As many here have speculated, this could be the root of the problem Tesla is not talking about.
Scientists pinpoint cause of harmful dendrites and whiskers in lithium batteries
It is certainly worth reading up about Dendrites.Dendrites were discussed here previously. This article helped me better understand what they are and how they are formed. As many here have speculated, this could be the root of the problem Tesla is not talking about.
The estimations are so far off now. Battery temperature needs to be close to 100F to get close to the estimate and decent rateArrived at a Supercharger today with 6 stalls out of 8 available, pairing with no one.
Started to charge @40% SoC, the display said 30 minutes to 90% (my old 80%).
Charge rate started at a hefty 50 KW to quickly tapering off.
It took 55 mighty minutes to charge from 40% to 90%.
(Ambient temperature 70F)
And if this is indeed the reason for batterygate and chargegate (and i believe it is), then this is clearly a safety issue and Tesla is in big trouble.
... Battery temperature needs to be close to 100F to get close to the estimate and decent rate
drive really hard .How do you achieve that? Plus, Tesla does not display the battery temperature.
