sure they are not warming instead of cooling?
not that I think that is the case but ??
could just be trying to get all cells at the same temp. there is quite a bit of variability between the inlet and outlet temps depending on circumstances
I'm starting to log data using ScanMyTesla and TeslaLogger.
First a description of the new behavior for charging in cold weather :
1: My car will not start to charge until the battery is approx 3,5C. Until that 2,6kW is put into the pre heater (icon is visible in the app, and the app just says "Charging" - no end time.
2: When 3,5C is reached, charging will slowly raise to 6,3kW - and pre heater is still on.
3: At 9,3C the pre heater will turn off, and charging is now up to 9,3kW (it is the max my car is configured to take at home)
Pump.
My best guess is that the pumps are running until the cell temp is down to approx. 15C. The 400V system is drawing approx 3-400W while the pumps are running (and the car is humming)
Here from this night. The car was charged directly after work. Cell temp at end (SoC 82%) was 28,6C, and you can see that the battery power (kW) went from -9,2kW (charging) to 0,3kW - this is the pump running. Here after 2 hours the temp is down to 23,6C. So my best guess is that the pump is running several hours
