On the other side the Taycan has at 150 km/h a similar range as the Model 3 LR RWD.
There is still a large difference between EPA and reality.
Charging Speed of Taycan is also much better.
Here in there is a considerable drop of charging speed during winter, not only because of charge gate.
I can only shake my head when someone says that Tesla is years ahead of the others. Tesla has been a bit lazy the last few years. With NMC the others have the better battery technology with higher cycle numbers and better charging speed.
So I hope Tesla is now pushing the limits to go ahead again.
This is absolutely interesting info, and it is a data point, but it's also cherry picking the best case scenario for the Taycan.
This is useful for showing the advantages of the two-speed transmission, heat pump, and aero, but the numbers would be much different if it were good weather at normal speeds.
EPA numbers obviously aren't accurate for Teslas at low temps and illegal-in-US speeds, but the test you posted are also nowhere near accurate at normal speeds and decent weather.
Case in point, Motor Trend's test where they achieved 369 miles of range in the "370-mile" Model S with 11% battery still remaining.
Or my trip this weekend that resulted in 199 wh/mile despite the AC/seat heater/4-people/70 mph (3LR RWD), which also easily beats the EPA estimate.
All these tests give interesting results... for that particular use case.
Pretending like one test is indicative of all use cases by making broad over-generalizations is nonsense.
NMC of Audi/Porsche has a much better lifetime and fast charging ability than NCA. This is also the reason why Tesla uses NMC for energy storage and not NCA, which is dead after about 500 full cyles or 1200-1400 typical charge cycles, that EM mentioned in the investor call after indroduction of the power packs.
Charge- and Battery gates are the symptoms of the weakness of NCA.
Please read the following studies:
NCA
NMC
Theory is cool, but it's time to go back to the drawing board if it doesn't line up with what happens in the real world. There are plenty of distinctly not "dead" Teslas with 1200-1400 charge cycles.
