raymondotango
How odd. I'm on slightly newer versions of AA and Waze and it definitely does not work for me. Google Maps is fine.It does for me:
Android Auto: 9.0.630813-release
Waze: 4.91.70.709
Waze: 4.91.70.709
Maybe it's your Waze version, I'm testing new versions for AA?How odd. I'm on slightly newer versions of AA and Waze and it definitely does not work for me. Google Maps is fine.
Yes, looks like it based on comments on Reddit.Maybe it's your Waze version, I'm testing new versions for AA?
Yes, all of the time. You can also respond to alerts via the car's screen.Has anyone used Waze app on this? and do you get the audio for alerts through car speaker? Thank you
I've not noticed any exclusivity between the apps, assuming the voice inputs are not used simultaneously. Tesla voice commands nicely coexist with TeslAA/AA commands.The one question I had though....is with Google Assistant as the default voice command, is there a way to engage Navigate On Autopilot? Eg) double click microphone button to engage Tesla voice control over Google Assistant?
2. Press the icon for the app tabthe bottom you want to become full screenI tried teslaa today.. I'm not sure I'll keep using it.. couple of problems:
1. It keeps staling and flashing on and off, which is pretty annoying when trying to navigate using it.
2. The screen layout seems fixed unless there's something I've completely missed.. 1/4 of the screen dedicated to the weather.. given the screen is already small due to having to fit into the tesla browser space is seems pretty wasteful. Waze suffers a lot from that, being stuck in the top half of the screen.
3. When you add a new app you have to reboot the phone and manually reconnect everything.. teslaa doesn't seem to ever ask the phone if there are new apps unless you do that.
Are you able to clarify how you engage Tesla Navigation via voice? When I press the microphone button on the steering wheel - Google Assistant is the default voice command. How are you able to engage the Tesla Voice command to use Navigate On Autopilot. (eg) I said "Navigate Home" - which was processed by Android Auto - not Tesla Navigation. ThanksI've not noticed any exclusivity between the apps, assuming the voice inputs are not used simultaneously. Tesla voice commands nicely coexist with TeslAA/AA commands.
I don't recall seeing any setting like that. When I press the Tesla button, it beeps, I say "navigate to...", and the Tesla map does so.Are you able to clarify how you engage Tesla Navigation via voice?
Thank youYes, all of the time. You can also respond to alerts via the car's screen.
Waze support for coolwalk is in the final stages of testing before release2. Press the icon for the app tabthe bottom you want to become full screen
After some fiddling around/reboot, your description of how things should work is correct. I can confirm, pressing the microphone button on the steering wheel still initiates the Tesla Voice Command, and Navigate On Autopilot works as it should. If you say "OK Google" it hands over the command to Google Assistant, and you can specify your destination to to Android Auto. Works very well. Android Assistant is definitely more capable in terms of understanding the user requests/destination names.I don't recall seeing any setting like that. When I press the Tesla button, it beeps, I say "navigate to...", and the Tesla map does so.
The way I talk to Teslaa is to press the microphone button on the Teslaa app on the Tesla screen. I then just say an address and the app recognizes it. Same microphone, different app/process. I could do a 30 second video if this isn't clear.
You are able to get a Google response via the Tesla talk button on the steering wheel? If you turn your phone off, does it revert to the Tesla voice app?
On long journeys I turn blue tooth off on my phone. The Waze navigation instructions come through the phone's speaker.I just installed this yesterday and barely played around with it, but it appears to work pretty well. I love using Waze for road trips, to get traffic/speed trap alerts.
As the audio is going through bluetooth, does anyone notice the typical 2 sec. lag you get? I didn't play with it along enough, but it appears there was a lag. Is there to hardwire it so audio isn't going through bluetooth, or is that the only way to route audio to the Tesla from a phone? Or maybe it's an issue on my end with the bluetooth handshake that is causing the latency/lag.
