LongRanger
Thanks that would be really kind of you! Obviously when ever you can.
Gareth
will do when it's not raining !
Gareth
and if it will be eligible for the OLEV grant being “smart”?
No chance it'll do 48A, supply caps out at 32A. It remains to be seen if the cable is much lighter - 3 phase 32A is pretty much a fixed standard and all cables seem to be the same width.
The shorter cable means although I'd like the wifi (which will presumably integrate with the tesla app) I'm not really interested currently - the current length is perfect for reaching the back of the car from the house.
We were close to having a 3-phase supply to our property when it was built 30 years ago, but just got away with a 100A single phase supply as at the time we used storage heaters. Now with improved energy efficiency, we can get away with a 32 amp charger with our heat-pump heating and cooling.It presumably can do 48amps but only on 3 phase ... the Model 3 has 3 onboard AC chargers each rated at 16 amps ... 3X16 is 48 ... of course hardly anybody in this country has a 3 phase domestic supply ... on single phase it uses 2 of the onboard chargers = 32amps (other charge points do the same regarding the 3 phase 48amp issue)
I suspect they are US specs rather than any concrete UK specsNo chance it'll do 48A, supply caps out at 32A. It remains to be seen if the cable is much lighter - 3 phase 32A is pretty much a fixed standard and all cables seem to be the same width.
