Well that would be brilliant, but I'm not optimistic.British English! Maybe it'll actually understand what I say now.
Maybe even coping with our confusing mix of imperial/metric?
“Open Arsehole” certainly sounds better to me…. HahaPerhaps “open butt hole” is a thing of the past![]()
Is there something you would like to confess??? ;-)“Open Arsehole” certainly sounds better to me…. Haha
TouchéIs there something you would like to confess??? ;-)
There is a bit of a tease - where?Tidal and in car audio discussion moved to
@VanillaAir_UK - Now you've added the link, my post makes no senseThere is a bit of a tease - where?
Unacceptable!Unfortunately just bad timing as the link was added in the amount of time the it took you to write your post and hit post.
Unfortunately some moderation actions are not atomic, so there will be times where posts are being moderated in stages (ie move and update references) and others might interact mid process, as was the case here. Your post was posted in the amount of time that it took me to go a fetch the link to the new post and add it back. I could have done things in a different order, but for the sake of a few second window of opportunity for quick draw macaw to step in, I kept things simple. It happens from time to time and in this case I also kept your post for continuity and not to delete and potentially cause other issues.
Sigh! I wish you hadn't. That brings to mind:'To brake, or not to brake..'
But is is more likely that if you have enough Shakespeares they will write 'Woh Woh Woh'.......Remember the old maxim about enough monkeys and typewriters and one will create the complete works of Shakespeare?
After nearly 4 years I'm convinced Tesla programmers work the same way...
