Electrician came today... we're going with a 10mm cable and a 50amp MCB in the house consumer unit. He was very much of the view that who knows what else you might want to run at the same time as charging the car so to avoid it tripping out then go large. He's doing his stuff on the 25th, so if Pod Point can schedule for 28th or 1st then I'll actually have a charger before my car!Yeh exactly, but obvs it goes without saying, get a pros advice, don’t take my advice as gospel, just sharing what I think is right and what I’d be challenging on.
I used a company called propcert the gentleman that helped me and guided me thorughout the process was called Edson. I reallt recommend that broker to install your charger. They only install wallbox or sync ev. I wanted an untethered charger so i got sync ev. I already recieved my charger by post and the installation is on the 22nd feb.Can any of you Leicester folks recommend a wall charger installer? I dont hold much faith in the person im chasing at the moment, barely has the time to respond to my messages.
My wuite was for £700 for an Sync Ev with installation and a load limiter. If ny meter was 100amp instead of 60amp it would of been £600Wallbox ordered from DRT electrical, £485 for the unit which was about as cheap as you can get. Electrician quoted to fit it, along with some other bits. So once its done ill post a comparison between that and the £747 I was quoted installed through the grant....I'm fairly sure it'll be cheaper this way.
Interesting, why the load limiter if you have 100a going in? do you have heat pumps, electric showers, solar or a larger home? I have an underfloor heat pump and a hot water Air source heat pump but electrician says the load will be far less than 100a and if it ever peaked above it would not be long enough to cause issues.My wuite was for £700 for an Sync Ev with installation and a load limiter. If ny meter was 100amp instead of 60amp it would of been £600
Nope, i have a 60amp electric meter the sales person said i need a load limitor as my meter is not 100 amp... did they mug me off for a £100?Interesting, why the load limiter if you have 100a going in? do you have heat pumps, electric showers, solar or a larger home? I have an underfloor heat pump and a hot water Air source heat pump but electrician says the load will be far less than 100a and if it ever peaked above it would not be long enough to cause issues.
No apologies, I think I mis-read that they were upping you to a 100a for that £100. So at 60a you may well need load management, for example if you have the charger at 32a and then a cooker, tumble dryer and hair dryer etc all pulling up to 13a and a load more stuff at a few amps each you could peak over 60a so the load management would kick in to avoid overload.Nope, i have a 60amp electric meter the sales person said i need a load limitor as my meter is not 100 amp... did they mug me off for a £100?
Ahhh, thanks for explaing that buddy! However, i saw online the same load limiter they sold to me for £100 was for £35 online. So they dod mug me for £65 lol. Tomorrow is the installation so ill let you guys know how the experience is. But £700 for sync ev +load limiter and installation is a fair price?No apologies, I think I mis-read that they were upping you to a 100a for that £100. So at 60a you may well need load management, for example if you have the charger at 32a and then a cooker, tumble dryer and hair dryer etc all pulling up to 13a and a load more stuff at a few amps each you could peak over 60a so the load management would kick in to avoid overload.
I assume they mean your cut off fuse is 60amps. Your DNO should be able to increase this to 80 or 100? From previous research DNOs have often come and done this for free, but it might take sometime though.Ahhh, thanks for explaing that buddy! However, i saw online the same load limiter they sold to me for £100 was for £35 online. So they dod mug me for £65 lol. Tomorrow is the installation so ill let you guys know how the experience is. But £700 for sync ev +load limiter and installation is a fair price?
I’m not a tradesman so not totally sure, but the CT clamps need a data cable from charger to meter to monitor load- the £35 version has a set length but many installers use EV ultra cat5 which is basically the power cable combined with data cable. It’s about £4-5/m more expensive than standard power cable and easier and neater than snaking a data wire around the power cable + £10-20 to fit the clamps and wiringAhhh, thanks for explaing that buddy! However, i saw online the same load limiter they sold to me for £100 was for £35 online. So they dod mug me for £65 lol. Tomorrow is the installation so ill let you guys know how the experience is. But £700 for sync ev +load limiter and installation is a fair price?
That's a great result. We've got 80amp cut off fuse without any load balancing/CT clamps. Mind you our PodPoint was installed in our garage (about 30m away from the main house consumer unit) which was already supplied with adequate cable supply into its own consumer unit - just had all the fuses changed to RCOBs by separate sparky and this made standard installation which was included in the PodPoint price feasible. So would have had to wire the CT clamp with a data cable back to the house which would have been a nightmare.I placed an order for a Hypervolt on the 18th, the installer contacted my DNO who emailed me on the 21st saying they have had a request to upgrade me to a 80amp fuse and to call them to book in. Called them the same day and they are coming out tomorrow to do the upgrade. I was expecting it to take weeks so pleasantly surprised at the turnaround.
