C
candida
Guest
Does it take you 30 minutes and can you only do it in places with specialist equipment?200-225 miles I need to pee anyway.
Next question
Next question
I know! Ridiculous! There will be rumours next that they want to eliminate stalks to save a similar amount!On a revenue of $59 billion (2021). That’s 0.17%, or the equivalent of someone earning 50k saving ~85 a year.
I really don’t think the conspiracy case that this about cost saving adds up.
Tesla generating this much ill will for such a small revenue saving would be like that person on 50k stopping buying toiletries and deciding to stink all year to save the 85. If their financial results come out and show that they’re in a difficult place maybe I’ll rethink but with the margins they already have I do not see this as a business decision anyone would realistically take.
The other fault in the ICE analogy is that one could regularly fill it to the brim and use it almost down to empty. For EV that would be horrible for the battery life. Additionally, larger batteries have longer life because you do not need to fully cycle them that often.I think the thing is that on ICE cars the fuel tanks are big enough that it's merely an extra cost issue from lower mpg vs having to fill up too often. EV's will solve this range issue once they get more dense batteries that even if they are quite out, the real world range will still be plenty. I don't think real-world ranges in the 100 - 200 mile are acceptable unless you want a little city run around. That's a range you might be hitting in some Tesla's for instance in the winter and more so in other brands of EV's. Similarly I don't think 200 - 300 is probably good enough. 300 - 400 is fine, 400 - 500 per charge is probably getting towards average ICE cars at a guess.
They can argue you need to stop and stretch your legs, go to the toilet or grab a bite to eat and charge during those times but going to the toilet, stretching your legs isn't going to take EV charging times. You could grab a sandwich and that ain't gone take as long and your forced to also stop somewhere that does have EV charging. I can get 600 miles out of a tank on my ICE, generally if I fill up at start of the journey there's little I ever do that I'd ever need to fill it up on a trip. Can stop anywhere I want, when I feel I need to stop and not the car.
This will come to EV's I suspect, just going to take a while for the battery tech to get there and be cheap enough also.
Some excellent points there.The other fault in the ICE analogy is that one could regularly fill it to the brim and use it almost down to empty. For EV that would be horrible for the battery life. Additionally, larger batteries have longer life because you do not need to fully cycle them that often.
Also, ICE are so inefficient that racks, cold/hot, small hills do not affect it as much as they do EV.
So, in practice, EV range is 60-70% of the advertised.
Don't know about you but I don't need to pee for 30 - 40 minutes though200-225 miles I need to pee anyway.
Next question
Some road assistance companies started carrying ~25kWh batteries for fast charging. I think there is a Finish company that makes those. The same idea like the current jerry cans. It gives you enough energy to get to the next charger and because the car is almost zero it does it very quickly.Some excellent points there.
The other issue is if you DO run out of gas at the side of the road, a lift to and from the nearest gas station with a 1 gallon can is all it takes to get you back on the road and get on your way again. Maybe vehicle to load partly resolves that problem? Oh, sorry that's for forward thinking companies.....
As long as you aren't frozen and empty. In which case it can take almost an hour to start charging once power is applied.The same idea like the current jerry cans. It gives you enough energy to get to the next charger and because the car is almost zero it does it very quickly.
But now you add in the 2÷ hour delay at a minimum for breakdown to attend.Some road assistance companies started carrying ~25kWh batteries for fast charging. I think there is a Finish company that makes those. The same idea like the current jerry cans. It gives you enough energy to get to the next charger and because the car is almost zero it does it very quickly.
Well, due to SC location, it takes up to 5 minutes to walk to toilet alone in some places)servicesDoes it take you 30 minutes and can you only do it in places with specialist equipment?
We are talking about emergency situations, not regular trips.But now you add in the 2÷ hour delay at a minimum for breakdown to attend.
You can refuel your horse in any grassy field. Stupid combustion engines and their need for dinosaur juice.Some excellent points there.
Next question
Not sure a shoulder height camera facing directly left or right is going to be much use for parking..Left pillar camera blinded so it's going to be an excellent exercise and flood of threads about parking in the dark and no USS![]()
If one camera is blinded by darkness, means that other cameras can be as wellNot sure a shoulder height camera facing directly left or right is going to be much use for parking..
They really need to fix this though, my plan is for the MYP to replace the wife's car and be our main mile muncher allowing me to buy something smaller and noisier for a toy, but until the Y gets "bibbers" that plan is going nowhere fast..![]()
