brandonee916
I noticed the sound of the Seat Belt chime isn't working consistently either on 44.1. Reported it
Running the latest version (44.2) and still having the issue. Hopefully 46.1 which was just spotted on teslafi will have a fix . Some days I have 0 issues and other days it cuts every 2 minutes. Although for some reason it seems if I actually open my Spotify app on my phone (rather than letting it automatically play when entering the car through Bluetooth) it does not happen. Could just be a coincidence though.I have the same issue. Does anyone know if the new software update for the cold weather changes for the Model 3 fixes this issue as well?
The issue with the audio crackle and then cut-out has happened to me a few times since 39.7. It occurred while I was streaming bluetooth audio from my phone and I had assumed that was the extent of the issue (even thinking it might have been a phone issue). I'm now on 42.2 and this morning the entire audio stack went into the weeds. Started with streaming from my phone but I then realized,
1. Turn signal wasn't making any noise
2. Pressing the voice command button kept failing (and there was no 'beep' to prompt me to begin speaking). So this prevented me from filing a bug report. I also checked to confirm I had a good cell signal in the car
3. FM radio and slacker streaming weren't just silent; pressing on the FM or streaming station icons actually didn't seem to do anything
4. I always get proximity alerts pulling into my parking garage and these didn't sound.
Once I had parked, I walked around my car to retrieve something from the passenger side. As soon as I opened the door, the radio started blaring.
Are all of these things failing for everyone else having the issue?
This has happened on my Model 3 once or twice since v9. Thought it was the bluetooth cutting out - but maybe not. Prior to v9 I experience what sounded like a single speaker cutting in/out like bad connection. I had scheduled service to check that out next week but that particular problem has gone away.
My audio system continues to "fail to boot up" sometimes when I power up the car.
So, far, this has worked 100% to reset it:
#1: Pull over / stop / put car in park.
#2: Use the touch screen service menu to pick "power off" with foot off of the brake pedal.
#3: Push the brake pedal to power back on.
Now the audio works again, at least until I get out next time then I "roll the dice again" on if it gets stuck or not.
This is really getting old, and I hope some OTA update fixes this.
It doesn't seem like a hardware issue, but more that the car is failing to properly reset/reboot some audio system component when you get out of the car, then get back in later.
I've had this exact thing happen 3 days in a row last week. My car is parked in a garage at home and when I left in the morning no issue. But when I left work, and these 3 days were extremely cold here, it had no sound at all and exhibited all of the symptoms you listed. Double button reset did not work. It would start working again after getting out and getting back in. This was on 42.2, I'm now running 44.2 and have not had it happen since, but it also hasn't been as cold either, but after reading here I see people in much warmer climates are having the same issue, so much for that line of thinking. Have a service appt to get my stuck frunk fixed later this week, guess I'll complain to the service center and see what this one says.
Thanks for this tip - I didn't know this existed.I'd like to suggest that everyone having this issue go to Tesla.com and report the issue. Make sure you check the option for "Escalate this concern for executive review". So, tesla.com, login to your account, click "Manage" under your vehicle, then click "Ask a question". I just did that and pasted the link for this thread and one other related thread.
So far it hasn't happened since 46.2. Before it was happening every few minutes.
I agree. Had the same problem in my MX. The intermittent radio/audio silence (no gps commands) happened to me the other day and the frequency was increasing on a short drive across town. By the time I Arrived at my destination my blinkers were not even working. as I was putting it park the entire system shut down/screen went black. Scary stuff. Walked back to my car about 5 minutes later and the self presenting doors didn’t work. Put foot on brake and car took a few moments to do anything. Eventually started up like it does after a reset.any ideas on how to escalate this? imo this is starting to become a safety issue (no AP notifications that it is being disengaged for example)
