I think 0 to just starting to move, but also REGEN comes on more slowly but continues more deeply after a second or two.
I remember the beta release notes mentioned improved regen on the 60kwh, is it showing up in your final release notes? It seems there are several different versions of release notes depending on car configuration.
I have a classic, pre-AP P85 and none of the above has changed for me.
Ditto. Now I haven't done instrumented tests, but my car feels exactly the same as before.
FWIW, forum member slcuervo and I did some analysis that suggests the throttle mapping is exactly the same in 7.0 as under 6.2. See more:
Firmware 7.0 - For Classic Model S - Page 99
So it seems obvious to me that this is what is leading some to observe better efficiency in 7.0. Torque sleep is only a very small fraction of the efficiency gain. The vast majority of the gain being that the car is simply delivering less power at any given throttle state expect for the extremes.
I honestly can't feel any difference with 7.0. It always was perfectly smooth and super easy to control at near zero. Mine is a pre AP classic RWD.
I had a loaner P85 with AP hardware and V7 installed and there was a big difference in throttle response. It needed far less push/travel on the pedal to start moving and power seemed to be mapped earlier. Kind of a more aggressive mapping. When I first got in my when it was new I noticed how much pedal travel I need to get full power. It really seem to use the entire pedal range. That has not changed with V7.
Why would Tesla implement for two different throttle mappings? Makes no sense, IMO.
I almost thought they gave me a non-P drive unit at my last swap!
Not sure why there is a difference. As I said, both cars where on V7, yet the newer car definitely had a more aggressive throttle. It also had a much more aggressive brake. The entire brake feeling was different. But that makes sense as they definitely changed the brake system with the AP cars. They added a system that can activate and modulate the brake for Auto Pilot. The old car's don't have that.Now this makes sense. It sounds like the AP cars have more aggressive throttles that have been "tamed" to perhaps match those of earlier vehicles?
I see no reason to change the throttle response of my pre-AP P85. It's always been butter smooth at all speeds, including slow speeds, and I never had any issues switching from Reverse to Drive. That part of the software update confused me, but makes sense why I didn't receive it - doesn't need it. It seems only the newer cars have this issue with smoothness and acceleration "curve".
Sure, but it is curious that others with pre-AP are reporting a noticeable change.
Sure, but it is curious that others with pre-AP are reporting a noticeable change. Also curious that, if the purpose of the update was to "tame the throttle" that AP cars running 7.0 still maintain a more aggressive throttle response. I can understand why braking may feel different, but acceleration should be exactly the same, AP or not.
I have not noticed any change in throttle response ever with my March 2013 car since receiving it almost 3 years ago.
