Just cause it's driver error doesn't necessarily mean it's simple.Pilot error. Very simple.
I was thinking of all the accidents the FAA investigates and the ultimate determination. It might have been caused by a number of root causes, like cardiac arrest, but it’s the human element that’s the real cause. Not the aircraft. Same with Tesla. I think there’s many people just waiting to pounce on Tesla as the problem when it’s “ the nut behind the wheel “ who is actually responsible.Just cause it's driver error doesn't necessarily mean it's simple.
Again, while it may be that the driver is ultimately at fault, we need to look at exactly WHY they made the mistake(s) they did. For example, Air France 447 crashed into the Atlantic because of an incorrect pilot response to a mechanical issue (pitot tube icing up) that caused the autopilot to change the way it operates (it went from what's called 'normal law' to 'alternate law'). The change in autopilot mode was not immediately noticeable (design flaw), but the aircraft crashed because the pilots thought the autopilot had more control than it actually did (pilot error) but they were led down that path due to poor design.I was thinking of all the accidents the FAA investigates and the ultimate determination. It might have been caused by a number of root causes, like cardiac arrest, but it’s the human element that’s the real cause. Not the aircraft. Same with Tesla. I think there’s many people just waiting to pounce on Tesla as the problem when it’s “ the nut behind the wheel “ who is actually responsible.
I think they just mishandled the situation. 5° nose up and 80% power is the prescribed cure for the situation they found themselves in. Their artificial horizon was still working.Again, while it may be that the driver is ultimately at fault, we need to look at exactly WHY they made the mistake(s) they did. For example, Air France 447 crashed into the Atlantic because of an incorrect pilot response to a mechanical issue (pitot tube icing up) that caused the autopilot to change the way it operates (it went from what's called 'normal law' to 'alternate law'). The change in autopilot mode was not immediately noticeable (design flaw), but the aircraft crashed because the pilots thought the autopilot had more control than it actually did (pilot error) but they were led down that path due to poor design.
That's a good point. Getting back to why people mistake the pedals in a Tesla, I do think there are contributing factors on top of people being idiots.The change in autopilot mode was not immediately noticeable (design flaw), but the aircraft crashed because the pilots thought the autopilot had more control than it actually did (pilot error) but they were led down that path due to poor design.
Yes. It's obvious they mishandled the situation. But the change to alternate law was not pronounced enough to really clue the pilots to the fact that the aircraft would no longer prevent a stall. Couple that with the fact that the pilot's and co-pilot's controls are both electronically controlled joysticks and not the traditional interconnected yoke where one pilot can get feedback on what the other pilot is doing, so they were working against each other (one pulling the nose up inadvertently while the other was trying to push the nose down) which prevented recovery from the stall.I think they just mishandled the situation. 5° nose up and 80% power is the prescribed cure for the situation they found themselves in. Their artificial horizon was still working.
Airbus and Boeing have very different design philosophies. Airbus wants to take the pilot out of the loop as much as possible. Boeing just the opposite.
The petition is from the same guy (Ronald A. Belt) which has thrown around many different theories on SUA (some of which seem plausible at face value, for example his previous regen braking theory), which have been disproven and denied by the ODI, with ODI saying he was misinterpreting data. The article doesn't mention that at all, but you can see the name of the guy. As such I would take this with a huge grain of salt.Apparently there is a new petition filed with the NHTSA claiming the steering hardware causes a voltage spike causing the accel pedal sensor to miscalibrate and causing real SUA. Breaking: NHTSA Petition Claims Tesla Sudden Unintended Acceleration Is Real (but Fixable)
the petition: https://www.autoevolution.com/pdf/n...d-acceleration-is-real-and-curable-217525.pdf
This is another paper written by somebody with nothing better to do. (Or maybe he is being paid by short sellers?)Apparently there is a new petition filed with the NHTSA claiming the steering hardware causes a voltage spike causing the accel pedal sensor to miscalibrate and causing real SUA. Breaking: NHTSA Petition Claims Tesla Sudden Unintended Acceleration Is Real (but Fixable)
I don't think he actually did that, he just described that you could test it that way. I doubt he has actually ever touched a Tesla.He simulates a dip by injecting a voltage at the chip, which is ok for testing purposes, but it makes a whole lot of assumptions about circuits upstream.
I saw the picture on page 20 with a wire to pin 44 on the chip and I assumed that was what he did himself. But you are right that the way he worded it suggests he might not have done it himself.I don't think he actually did that, he just described that you could test it that way. I doubt he has actually ever touched a Tesla.
Yep, that would be the way I would test it too. That would eliminate a lot of assumptions about a whole range of circuits in between. Even with this test, the other thing to test would be if the steering motor (or other real car loads) actually would produce such a spike and for how long.I would think a better test would be to hook up a Iarge 12v load that you could control to stimulate what he thinks the EPAS is causing.
Yeah, I think that picture, and all of the other inverter pictures, are from Damien Maguire's videos of his hacking efforts to make it so Model 3 drive units could be used in EV conversion projects.I saw the picture on page 20 with a wire to pin 44 on the chip and I assumed that was what he did himself. But you are right that the way he worded it suggests he might not have done it himself.
@wk057 do you want to take another look at this guy's work? (Is the DC-DC converter limited to 200A and can be overwhelmed by the EPAS?)
Yes. If you've ever been a passenger with a younger driver or someone who's going too fast and realized that you've been pressing your foot against the floor, you know how automatic this can be.When people hit the accelerator pedal and think they're hitting the brake pedal, I think the faster the car accelerates the faster the driver tends to panic. Since Teslas accelerate quicker than most other cars, more drivers tend to panic than in slower cars.
