Gatsojon
I’ve just checked mine and it’s saying 288 miles. That’s M3P 38 months and 26k miles.What would be normal degradation after 13k miles and 18 months? I'm reading some people having 4-5% after a year and tailing off after that
Discharging the battery is actually required, before removal of the pack. If they do it according to the maintenance procedure, your LV battery should not be discharge/damaged, but we've seen some cars that got a new LV battery in the process.Wonder if I’m going to need a new 12v battery too. Doors and boot left open all weekend (and tomorrow I imagine) and the HV batt has dropped from 17% to 4%. Wonder if this is going to drain the 12v batt too…..
This thread is about the Panasonic 82kWh NCA pack with 5.0A low cobalt cells. Your degradation report is about the Panasonic 78kWh NCA pack with 4.8Ah high cobalt cells. Your older pack seems to be aging a little better than the one we are discussing here and it certainly charges faster!I’ve just checked mine and it’s saying 288 miles. That’s M3P 38 months and 26k miles.
Also let us know what part number you have on the invoice.My Q4 2021 M3P (23k miles) is also in for a new pack. Been there for nearly 2 weeks now, the car hasnt moved a mm and they are waiting for my pack to arrive - it’s on a ship somewhere.
I was at 294 ish miles at 90% and hadn’t even considered they would put a degraded pack in! Will keep an eye on it when I get it back.
Update - the car is now inside, boot, bonnet and doors are open so guess they have started something!
for reference, the service center have left mine to discharge too. Woke up today and it’s at 0% according to the app. Let’s see if I get a new 12v battery or notDischarging the battery is actually required, before removal of the pack. If they do it according to the maintenance procedure, your LV battery should not be discharge/damaged, but we've seen some cars that got a new LV battery in the process.
I’ll take @eivissa lead on this one, but it looks like over on the German forum that the range decreases after a few charges - not increases.So it’s charged to 94% overnight and showing 260 mile range. That is a huge drop in what in what I used to have.
Is range likely to increase with a few charge cycles on this or with it being (likely) a refurbished pack is it already at its optimum output?
It might go up, once you charge it to 100% and the BMS finds more capacity above the expected 100% and after a couple of cycles. For most it didnt change much anymore. In your case, the most interesting part is, which part number did you get?Is range likely to increase with a few charge cycles on this or with it being (likely) a refurbished pack is it already at its optimum output?
1137377-01-W
You rated range matches packs with part number 1137377-##-#
Well, there you go. That is a refurbished/remanufactured Panasonic 3L. So it is the correct battery pack, but these were the ones with the worst capacity so far. I have had some customers come to me for a BMS readout and there were some packs with over a 100 cycles already. The donor car must have done almost 100k miles before it was "refurbished". Not to say that you one will have those values, but your reported range so far, matches the bad range that others have reported with this part number.
For round figures, a cycle would be ~300 miles. So that pack had about ~30k miles on it before it was refurbished...I have had some customers come to me for a BMS readout and there were some packs with over a 100 cycles already. The donor car must have done almost 100k miles before it was "refurbished".
I have no idea what Tessy App is reporting, but it certainly can't read the true BMS data.My own battery report from Tessie app states I have 251 cycles and this on an original battery (M3 SR+) after 33,000 miles ... so how does 100 cycles equate to 100k miles?
Well, I said "over" 100 cycles, right? Sorry if this triggered an answer.For round figures, a cycle would be ~300 miles. So that pack had about ~30k miles on it before it was refurbished...
You’ve got a smaller battery, more cyclesMy own battery report from Tessie app states I have 251 cycles and this on an original battery (M3 SR+) after 33,000 miles ... so how does 100 cycles equate to 100k miles?
I appreciate that Tessie will be extrapolating from a less than full picture because I only started using it a few months ago so accuracy will be questionable. The cycle difference because of the smaller battery will be in proportion… about 25% more cycles for the same distance as a LR or Performance battery by my reckoning.You’ve got a smaller battery, more cycles
For reference, Tessie says 62 cycles for mine at 12k miles. It knows my loan has 166 cycles at 24k miles - so must be getting that from somewhere
