Alexander
P# 8,878
My standard charge only yields 234 miles of range. I haven't done a full charge yet. Is 234 miles on a standard charge normal?
Yea, my A pack at just over 1 year only gets about 215 at 90%. The B folks not only got better SC, but the initial year's degradation seems better.
Out of curiosity, which battery (A or B) do you have?
Not to get too pissy about this, but without a bunch of specifics from the Service Center about what they are talking about I'm calling BS on a "change in algorithm" as a general excuse for why we are seeing full range charges in the 240s. If you walk them over to any new loaner car with only a few miles on it, and the same exact software version, they all show in the 265-270 range.
Peter
PS. If they want to talk specifically why a range charge now charges 2-3 miles off of where it did the day before an update, that's something different.
PPS. I'm in the high 240s, also... I'm curious if anyone with a "B" battery is in the 240s...
Not sure if we have an "A" or a "B" pack. I checked the front passenger wheel well area for a battery sticker and couldn't find one. Found stickers for some of the suspension parts though. Not sure if it makes any difference that our pack was swapped out some time in April or May after a contactor failure left us stranded. Any other place this battery sticker could be???
So no EU reports? Even if it's a car you just got it would help to set a baseline. Am on 5.8.4 myself and as mentioned 492.5km rated range, 394 typical.
See post #577. Putting suspension on high and turning wheels to left will make it a bit easier to see the label.1300 posts... Anything more specific? Thanks!
I did my first range charge today, Dutch. 493.1km rated and 394.5km typical range.
Excellent, we're within half a km and as I had to leave before the pack was fully balanced that might be about right. You are on 5.8.4 as well?
I am at 10 months with just about 19,000 miles. I also get 215 at 90%
I wanted to summarize a few things I've been seeing in the posts:
To see if you have lost range, do a few 100% --> 0% --> 100% charges. Does your range increase each time? If so, great, range returned through balancing. This may help you if you have been limiting your charge to 50%-80% for some time. And, if you do the repeated 100% --> 0% --> 100% charges and don't see an increase, then you know that you have lost some range.
With regards to hidden range, it exists to a certain extent, but because new cars and some older cars are seeing 265 miles on a full charge, if your full range charge is less than 265 and it's not returning when you do 100->0->100, than you don't have anything hidden from you.
Thoughts?
