So what reason do you see that range numbers are not comparable between two cars with the same firmware and the same A battery? If you skim through this thread you will notice that 240 seems quite low even for an A battery. And compare that to what walla2 used to have (A battery with 260+ rated and only a few thousand miles). I see a clear distinction between the packs.
No, you don't see a clear distinction between packs but clear distinction between the numbers those (different?) range estimation algorithms spat out.
No two packs are driven and charged under exactly the same conditions and no two packs are made exactly the same.
There is only one somewhat reliable capacity estimation method:
1. discharge until some low cutoff voltage is reached
2. charge until some high cutoff voltage is reached
3. count Wh used between those low and high cutoff voltages
Those Wh are the upper limit on possible battery capacity. It can be less, but not more.
Now discharge the battery under some predetermined discharge profile #1 and count Wh 'extracted' until that low cutoff is reached again. You get capacity estimation #1.
Repeat with a different discharge profile #2 and again count Wh 'extracted'. You will get a different number of Wh. That is capacity estimation #2.
Repeat with yet another discharge profile #3 to get capacity estimation #3.
Repeat with discharge profile #1 at different temperature. You will reach to capacity estimation #4.
Etc.
See the problem?
And don't forget that by doing such measurements, battery degrades.
So, the only thing a rational man can do is to stop obsessing about 0,5% range differences. It means nothing and nothing at all. There is a computer in the model S that knows a bit more about the battery than "249 mile rated range". It will tell you when there is time to call Tesla.
265 miles range does not mean 265 mile range, it means
a) you will probably get to that town 200 miles away
b) you might get to that town 250 miles away
c) you probably wont be able to drive to that town 300 miles away
