smac
The cars display of range may have nothing to do with the actual range and the actual battery capacity. That is, your battery could be seriously degraded and still display a "normal" range. My 90D when fully charged (done only a few times) shows a "rated" range of 275 miles or so. No way. Even when consuming only at the rated consumption of 324 wh/mi (difficult to do), my actual range is about 220 miles.
@PeterLucas
It might not even be showing us an accurate Wh/mi for all we know.
If I were a devious sort of guy and knew that people were looking at range in miles at 100% and the total amount of kWh drawn in the trip computer. Do you know what I would do? I'd mess with the definition of a Watt.
The logic would be that instead of W = Watt. W = Whateverwewant,
It would be much harder to notice / monitor degradation from an end users POV, if you then changed the Whateverwewant over time to track capacity.
The WhateverwewantH/mi would remain broadly consistent, so unless you were doing a full charge 100% to empty, you'd never know.
Maybe if you did do a full 100% to 0% range test periodically and compared it to miles driven (which hardly anyone would do), variations would be put down to experimental error (traffic, speed, weather, etc. etc.
The total Whateverwewant capacity would still tally with the trip computer, the range of Whateverwewants vs the typical Whateverwewants * capacity expressed in Whateverwewants would be the same.
Note, I'm not saying this is happening (and I don't believe it is otherwise Tesla would have done this from day one with the 85kWh pack!! If the W had stood for WhateverWeWant,, the trip computer from full to empty could have actually displayed 85kWh to match the badge on the back )
