dirkhh
Middle-aged Member
Are you planning to make this "classic Model S"-only or broader? In the latter case I'll add my name, of course!Ok, I'll draft a letter with our comments tonight or tomorrow, and I can send it in to TM with our names.
The only way that would work would be to completely erase everything and start over. A better approach would be an SDK. Then we could fix things ourselves or purchase an App that fixes things.
Nearly every piece of hardware w/firmware of any consequence has a rollback capability. Even failed Tesla updates rollback, if my memory serves one time I had an update fail.
I think rollback is probably already there in reality, but we don't get to touch it.
Tesla should not have to support every software variant for ever and ever. Heck, I'm typing this on a browser that reminds me every time I launch it that I'm no longer supported on this 6 year old Mac. Manufacturers have a right to draw a line around how many and what versions they will support.
But you and your Mac have a choice whether to take an update or roll it back. With the MS, you don't have a choice.
If you update your iOS device, you can't roll back. There are some devices with limitations. I'm not defending one or the other; just clarifying that the MS isn't alone in this category.
The only two things wrong with the 17" screen (not counting Nav) are the climate controls (too dark and information removed)0 and the lack of the outside temperature.The easiest way to satisfy us "classical owners" would be to give us a config choice between "New" and "classical" instrument cluster. They have the code for both and the parameters show are mostly the same.
This is a simple and manageable demand for an overworked SW-team. The;17" is acceptable in the new version. And since it is an input device its more complex to make a "classic" version of.
If you've never used the old version, the new version probably looks okay, as it's no worse than an ICE display. It's when you've had seen how good the display can be that the problem arises.It's surprising how tolerant Tesla owners continue to be about some of the software issues we're seeing. Will the much larger number of Model 3 owners be this forgiving?
Still problem FM radio problem free over the weekend. So V7.1 (2.12.126) seems to have fixed it.
My car has always worked this way. What changed in the last couple of updates is that there is now a setting.now all doors are open if you touch the passenger door.
When did the door unlocked change. You had to touch the drivers door to unlock the door you could not touch any of the door to unlock the car . The door will only unlock on a drivers door and you could not touch any other door to unlock it. now all doors are open if you touch the passenger door.
I keep waiting for the 7.1 build that addresses all the glaring issues that it introduced. You know, the low contrast speedometer, the completely broken A/C settings, the glaring headlight halo from the toy car - that stuff.
Instead we get "creep setting is now stored per user", "audio source shortcuts are removed", "actual speed that autosteer is limited to is shown in the warning message".
I have made so many derogatory statements about the software teams at Tesla over the past couple of years but this is getting to the point where I really wonder what's going on. How can a serious software organization be so blatantly oblivious to the ACTUAL problems of their user base? Who is in charge of prioritizing the bugs that get addressed?
/chuckleElon, and he gets his list from his wife/not wife/wife again Talulah.
I'm on 2.13.77 on both the S and the X, ... I also miss the unlock with the double press of the button on the gear selector (it now activates summon/park).
