Not conclusive, but it is suggestive.Size and number of inputs.
That shows the single SoC configuration. Tesla is using the double SoC configuration. Nvidia however suggested two PX2 double chip boards are required for fully autonomous driving and that Tesla's configuration is only sufficient for "autochauffeur".At 9:59 the slide shows that px2 is only sufficient for L3 autonomy?
Saying something is "sufficient" is an unknown at this point since there are no true lvl 5 cars on the road.At 9:59 the slide shows that px2 is only sufficient for L3 autonomy?
Okay, maybe they are using a "custom" double SoC board. But either way, they definitely aren't using the small board in that picture.And you know that for a fact how? All we know for sure is that Tesla is not using the NVida designed boards, they made a custom one. So we have no idea how many chips are on it.
double SoC board
The non-small form factor Drive PX2 "system" consists of two SoCs and two GPUs and it's the same approximate shape as the enclosure in the AP 2.0 cars. Until someone opens one up, most of us are assuming it's not full of empty space.Again, how do you know it is a double SoC board?
But the connectors are outside the box and cooling is likely happening with those black sections on the top:A bunch of that space is necessary for all of the connectors. And more of it is necessary for cooling since Tesla didn't go with a liquid cooled setup.
Not 100% sure yet, but so far in the other thread there are two nodes in HW2, one called "ape" (which seems to handle EAP) and one called "lb". HW1 only had 1 node.Again, how do you know it is a double SoC board?
BTW, HW2 systems added 2 more computer systems (As in network-accessible) compared to HW1, one is eap itself, the other one is cryptically labeled lb, but I have no idea what is it and when is it on if ever.
Anyway important parts - for lb I only know the name and adress, but it's not on ever as far as I can tell.
the diagram noting A-B link is gige seems to imply B host is a separate node, so a high candidate for this LB stuff.
EAP node is actually called ape.
How do you think: would it be possible to fit this one instead of AP1?With a little help from my friend w/AP2, I just captured some nice pics of the AP2.0ECU! Managed to do some measurements to (metric):
Now - someone with the b**** please unscrew that thing and open it for us to see its guts
