... a couple of more-forward side cameras would go a long way here, but even when there was no visibility issue and clearly no other cars it was slower to make a turn than I'd have been- might have to try the aggressive setting next time.
(quoting you not to argue with you, but you sparked a thought I've had several times from numerous other posts relating to forward side cameras)
I think the "we need more-forward side cameras" concept is popular mostly for the wrong reason. I've seen lots of times where the car crept... and crept... and crept before finally deciding to commit to a turn. Yes, some of those involved limited visibility to the side. However, in my personal experience, the vast majority were situations where there was no visual obstruction at all, so an a view from an additional angle wouldn't have helped.
However, one of the points made on AI day was how much better the perception can be when you merge the data from multiple cameras into a singular vector space. I specifically recall visuals from around 20:47 into this video, where the difference in quality is super obvious:
AI Day Single Cam vs. Multi Cam
The glaring problem I see is that if fusing data from overlapping fields of view is required to generate that high quality perception, what happens to the large areas to the sides of the car and narrow area directly behind the car where only one camera can see that area?
Note the large areas left and right of the car where only the light green "Wide Forward Camera" view can see:
Screenshot taken from
Autopilot
These areas can't benefit from fusing data from other cameras to improve their accuracy. Sure for fixed objects like curbs, you can remember where you saw something in the other cameras as you approached, but when detecting moving objects like crossing cars, you have to rely on live data you see right now, and there is no other data source that can help you see it.
So, I suspect FSD's perception in those left and right areas is no better than the low-quality "before" images shown in Tesla AI day, and without additional sensor, can never get as good as the "after fusing into vector space" images.
