EVNow
The exact logic Musk uses to say FSD will be cracked every year.It’s so close to 90%! I’m sure they’ll get there this time.
Ofcourse, FSD isn't actually that close to being cracked .... but thats another story.
To be a really good engineer you have to be an optimist about the ability of engineers to overcome technical obstacles. Plus, overfitting is your friend.Is @Daniel in SD STILL betting on FSDb??
I thought it'd be painfully obvious that FSDb is only going to improve gradually at best...
My manual drives were nearly flawless. I even have video proof! Literally zero use of the brake pedal, negotiating about 22 intersections, each direction. I did not even attempt to run any red lights when driving manually (foreshadowing). Tesla makes it easy to drive basically flawlessly.I wouldn't expect a "flawless" drive from FSDb .... or for that matter from 90% of people.
My wife doesn't yell at me when I drive compared to when FSDb drivesI wouldn't expect a "flawless" drive from FSDb .... or for that matter from 90% of people.
Great ! You are in the 90th percentile, then !!My manual drives were nearly flawless. I even have video proof! Literally zero use of the brake pedal, negotiating about 22 intersections, each direction. I did not even attempt to run any red lights when driving manually (foreshadowing). Tesla makes it easy to drive basically flawlessly.
This is a good point actually. In order to get 100 on safety score, you can't use your brakes. If you're an OG tester that got in at 100 (like myself) driving without brakes is easy.Infact 99% of drivers use the brake. In each direction.
One FSD behavior that has improved a lot for me is the reduction in attempting to pass stopped cars instead of just waiting until traffic moves. Doesn't happen very often to me now.Even as the long truck in front was making a turn to the only lane, FSD couldn't figure out what it was doing and wanted to pass. This is not going to be easy .... but no harm in not trying to pass large vehicles at intersections, whether the truck is trying a wide turn or not.
My wife still holds onto the door handle when FSD is enabled for city/streets so I keep FSD to a minimum when she is with me.My wife doesn't yell at me when I drive compared to when FSDb drivesI think that's a minimum definition of flawless
My wife hates Elon so she won't get in my car!My wife still holds onto the door handle when FSD is enabled for city/streets so I keep FSD to a minimum when she is with me.
Funny enough, when I let my friends drive, they hate the regen and use the brake. I've been asked how to turn it off.This is a good point actually. In order to get 100 on safety score, you can't use your brakes. If you're an OG tester that got in at 100 (like myself) driving without brakes is easy.
Since they've dropped the requirements, many people who've joined in the 80s/90s probably have trouble proactively slowing and staying off the brakes and hence find the discussion of using brakes by FSDb to be strange.
What you see in the visualization that was inaccurate?
And what's the purpose of arguing counterfactuals? It didn't hit the other vehicle because the driver disengaged. You can't say it would have hit any more than I can say it wouldn't have.
I wish I could find a car my wife would refuse to get in. I would buy 2.My wife hates Elon so she won't get in my car!
It does have 1 advantage, she doesn't know a single thing about Tesla.
I mean literally nothing, which means she has no idea what the Plaid cost.
"So I got that going for me, which is nice"
I’m starting my experiment for my commute using the easiest route with most surface streets. There is a way with all surface streets but can try that later.
