Wow, your LEAF battery must be newer and in better condition than ours, which has at least 25% capacity loss. The other day, with a battery temperature in roughly the 40s Fahrenheit (maybe 7C, or four battery temperature bars) and a relatively low battery (2-3 bars of charge remaining), my regen on the LEAF was maxing out at only 10-15 kW. Plus, the LEAF firmware has this really annoying "feature" that reduces available regen power (in kW) as the vehicle speed increases. This makes regen on our LEAF mostly useless for descending the mountain we live on, so nowadays we hardly ever use the LEAF when going "down the hill".
The regen on our 2012 Model S tends to be far more effective. While the Model S does limit regen when the battery is cold, preheating the car helps significantly, as this prompts the car to run its battery heater. It's also helpful, as with any EV, to finish charging shortly before driving because charging raises the battery temperature. While our "new to us" Model S hasn't yet experienced temperatures way below freezing, it's done great at regen so far. Even when charged as high as 80% or 85%, it's still able to regen all the way down our 4900' / 1500m mountain descent with scarcely a need to use the brake pedal.
