I just installed the filter into my MS. A few tips - 1) the side plastic wings have a rubber grommet that you pull thru the wings on disassembly. But for reassembly, they unscrew. Set in the wings, then screw in the grommets. 2) I could not tell which of the 18 bolts you were pointing to (your video of the mouse was too small for me to pick out), so I removed them all. In hindsight, I still think all 18 bolts needed to come out. Can't figure out why you thought only a subset needed removal. Once bolts gone, the tub pulled out nicely (watching for the trunk release switch and frunk light). Somewhere somebody said they were 3/8 bolts - but on my car they came off with a 10 mm metric socket. 3) I did not need to touch the duct work from the tub to the dash- no hoses, clips. Just pop out the tub and the filter socket is pretty obvious. The 14x27.5x1 filter from FilterBuy fits like it was designed for it. 4) Those 18 bolts fit into nuts that are "permanently" attached to the frame. One of those backup nuts came loose on my event, so I had to hold it with a vice-grip as I tightened the bolt. That was the only hitch in the entire process. Total elapsed time from hood open to hood close - 15 minutes, plus one band-aid for rug burn.
And - the filter had a "direction of air flow" arrow printed on its side.
Thanks for the post!!!!
