sorka
I’ve got 55k on mine in 15 months. V3 pack, 85% on supercharging. I am throttled.
What's your maximum charge rate?
A 75D uncorked is putting out about 350kW up until something like 70 MPH, isn't it? That is over 4.5C for 5 seconds.5.5C for the ludicrous cars. A fraction of a second. If true.
But cruising at 210-230kph or so is the maximum for the 18650's, just about 1C. Porsche wants to cruise at 250kph to empty.
I haven’t seen over 95kw in a long time. I used to regularly hit 110+What's your maximum charge rate?
Of course not. But say within the 8 years, your battery pack goes bad, maybe not because of supercharging but other reasons, maybe you can ask for v3.You would pay upwards of $20k for a replacement battery just to get faster supercharging?
Are you sure you have the v3. I thought I had v3, but later found out I dont have the right part number so it couldn't be v3.I’ve got 55k on mine in 15 months. V3 pack, 85% on supercharging. I am throttled.
You would need about 60 plus see degradation. But so far it looks like you are on your way. Mine started at 118kw. Then dropped to 108kw like yours around a couple of dozen, now pretty much settled at 96kw max though I can see that slowly going down to 93kw sustained now. I suspect it will never stop. I.e. eventually I will be charging at 80kw max...What does your curve look like? For comparison I have a couple dozen sessions in 16k so far. My last session peaked at 108kW and was still at 94kW at 50%.
I believe YouTube superstar Bjorn Nyland kept getting 94kW once he suddenly hit that throttled speed. Same on his second 90 pack still today. I could be wrong. Better geeks than myself will know.You would need about 60 plus see degradation. But so far it looks like you are on your way. Mine started at 118kw. Then dropped to 108kw like yours around a couple of dozen, now pretty much settled at 96kw max though I can see that slowly going down to 93kw sustained now. I suspect it will never stop. I.e. eventually I will be charging at 80kw max...
I went back to my notes from my very first session. 110kW peak. My next to last session peaked at 112kW. At this point it just looks like variability in cable quality and temperature.You would need about 60 plus see degradation. But so far it looks like you are on your way. Mine started at 118kw. Then dropped to 108kw like yours around a couple of dozen, now pretty much settled at 96kw max though I can see that slowly going down to 93kw sustained now. I suspect it will never stop. I.e. eventually I will be charging at 80kw max...
Did you read the thread, including confirmation from Tesla of throttling?There are a lot of anecdotes in this thread that imply throttling, but which in and of themselves are not proof of it.
Also the condition of the supercharger, cable, and handle. Well documented in threads over the past few years about low supercharging rates, especially at heavily used ones in California. Supercharger tech changed cable and/or handle and speeds jumped up!There are a lot of anecdotes in this thread that imply throttling, but which in and of themselves are not proof of it.
The biggest lurking variable is battery temperature. There are times I will plug in a 5% full battery and hit 116kW, and there are other times I will plug in a 5% full battery and never reach 80 kW. Sometimes the battery just doesn't warm up enough until you're well into the taper. This is especially common in cold months and climates.
I believe they determined it was a count way back in the beginning of the thread but I can't remember if they decided the number was 250 times (or what). Also, if you see the data available concerning charging and the battery, you can see it tracks the number of times you've charged, supercharged, etc.
There was some post saying v3 of 90kwh pack does not have tapering. Not sure of the validity of the post but if that is true, there might be some hope for us 90kwh pack people to ask for the v3 replacement?
@Naonak, can I ask how what your DC and AC charge totals are? I just set up a diagnostic port cable so I could use scan my Tesla and see that I have a DCFC total of 7848 kWh and AC total of 526 kWh for just about 22.5k miles. Mostly we drive cross country so are using a lot of Supercharging. SMT reports a nominal full pack of 95 kWh so I'm about 7% down over 16 months. I have not detected any throttling yet but I also have a 100 kWh pack which I think I can infer is not supposed to be affected anyways. But with all the DCFC I've done I'm at the high end degradation for my ownership time I think.
There is no “proper ratio”, but if you routinely charge at home and use supercharging for trips, you have nothing to worry about.I want to avoid charger throttling on my Aug2017 MS75, now with 7300 miles. How often can I use an SC between slow charges at home? Is the proper ratio 1SC for every 4 slow charges?
