The major difference being that Tesla's existence is fragile at this point, whereas Apple is worth hundreds of billions of dollars.
That changes the curiosity of the owners of the product, how?
Interesting that they use such a small wire to carry the current from each cell. It looks to be no more than 26ga wire or similar? With over 7000 cells in the pack and a peak power draw of 310 kW, each cell is responsible for about 45W under peak load. With a lithium-cobalt cell having a nominal voltage around 3.7V, that's about 12A per cell over that tiny wire. Sure the wire is short, but I still have to wonder how much power is lost in each one under heavy load... I'm sure one of you EE guys will be able to calculate this quickly.
Don't forget that this small wire is intended to act as a fuse, to protect the cell from overload.
I am curious why Tesla did not go with Li-Fe batteries that are much safer, highly stable, retains high capacity (>80%) after 3,000 cycles of charge/discharge and would be well ahead of competition (probably cost!). I don't know safety aspects of Li-Ion from crash testing and fire perspective. There has been reports of Li-Ion battery issues sporadically world wide (latest being Dreamliner). Any thoughts?
Besides from the sucky energy density, Tesla makes up for the cycle life deficiencies of the cobalt based cells (LiCoO2 in Roadster, NCA in Model S) by using lots of them. Example: 73 miles*3000 cycles = 219000 miles of use, 265miles*500 cycles = 132500 miles of use (the numbers might be better for the larger pack than indicated, because the larger size also means the discharge rate is lower, which improves cycle life).I am curious why Tesla did not go with Li-Fe batteries that are much safer, highly stable, retains high capacity (>80%) after 3,000 cycles of charge/discharge and would be well ahead of competition (probably cost!). I don't know safety aspects of Li-Ion from crash testing and fire perspective. There has been reports of Li-Ion battery issues sporadically world wide (latest being Dreamliner).
What I'm struck by is the empty space and space used for cooling. It looks as if it cuts the energy density of the cells by quite a bit. A prismatic cell that didn't need as much cooling could potentially raise pack density even if the cell density was lower. A123 EXT cells maybe? Certainly room for improvement at some point.
And yet Tesla still has the most energy dense pack.What I'm struck by is the empty space and space used for cooling. It looks as if it cuts the energy density of the cells by quite a bit. A prismatic cell that didn't need as much cooling could potentially raise pack density even if the cell density was lower. A123 EXT cells maybe? Certainly room for improvement at some point.
