Isn't this car wide, at 2011mm (79.2inches)? I know it is out of question in Japan, but how about Europe?
And yet, the 2018 Bolt EV’s EPA highway rating is 110 MPGe whereas the 2018 Nissan LEAF with the ~40 kWh battery pack gets 100 MPGe EPA highway. Meanwhile, their city ratings are nearly identical at 125 for the LEAF and 128 for the Bolt EV.But the Bolt really isn't that aerodynamic, actually it's pretty bad. And the Leaf is pretty close in Cd, but surely a good bit lighter. Therefore the WLTP to EPA comparison should at least be similar, right? So yea, I don't really know what to think.
The 240 miles of EPA range as estimated by Jaguar is abysmal out of a 90 kWh pack. The much bigger and heavier Model X gets that kind of range out of a 75 kWh pack. The usable capacity is 85 kWh versus 73 kWh for the same range (240 versus 237).
WLTP correction factor looks like it is closer to 15%, so based on 292 WLTP, that’s 248 EPA.
Also, what is which the underspec on-board AC charger? 32 amps for a 90 kWh pack, 10 hours for 80% means you can’t pull into a hotel near empty and leave the next morning with a full charge in 10 hours. Full charge is listed at almost 13 hours. This is an odd cheap out for such an expensive vehicle.
Charging to 80% in 45 minutes (official specs from the brochure) means slower charging c-rate than a Model 3. On a miles charged per hour basis, the I-Pace is particularly horrid due to the low efficiency, especially since the I-Pace has less passenger room than a Model 3.
Biggest unknown at this point is liquid thermal management. There I could not find any mention of such in the brochure or other literature released yesterday. Jaguar writes about advanced thermal management but provides no details. The cut away diagrams also don’t show it, nor did I see it in videos showing the pack and cells.
I have had Jaguars since 1970 and 5 years ago went to Tesla, it was the only car I would buy other than a Jag. I like the ipace and glad to see Jaguar go the bev route, the only down side for me is charging infrastructure that is lacking. If that improves I might be back to Jaguars.Well, I am on my first Tesla now and never had a Jag, but this one got me interested.
I tried the configurator and for the same money as my Model S 75D configuration, that I plan to replace my 90D with in October/November, I could get a very nice I-Pace.
I’ll of course test drive it first, but at least it’s a contender!
Yep. It’s too soon to really know but for now I am assuming about 83-85 kWh usable on a 90-92 kWh nominal pack and 80% of that is about 67 kWh. On a DC charger that implies an average charge power of about 89 kW. They claim to charge at up to 100 kW during the first 15 minutes of charging starting with an empty pack.One possible answer for the apparent low range is that they have a lot of buffer at the top and bottom.
It's the lack of three phase charging that some find sub-par.I'm not sure it's cheaping or as such - I think it's more using typical parts without recognizing the impact.
Aside from Tesla and that 43kW AC charging car in Europe, I don't think there's anyone doing more than 32A AC charging.
The BMW i3 has an 11 kW charger (16A 400V three phase). So does the B-class Electric Drive (with Tesla charger). The Zoe does 22 kW or 43 kW (32-63A 400V three phase). The Model S and Model X have 16.5 kW charging (24A 400V three phase).
People were expecting more. There are *many* 11 kW and 22 kW chargers in Europe. 22 kW chargers are even becoming common in private parking garages, where you have load sharing.
BTW: If you connect an i-Pace to an 11 kW public charge point, you will get a measly 3.6 kW. It will only be able to use one of the three phases. That sucks especially much since you will usually pay for the full 11 kW, regardless of how little you can utilize.
That seems hardly worth the effort...
They have to do it. But they don't have to like it or advertise it... people might think about buying electric cars if they did that.I think this is mostly because EA is not yet actively flogging the map in a press release and most coverage is driven by press releases.
That is a froot.Ha, true. Magazine holder?
