mitch672
Hi Mitch,
So is that your prediction for June 20th? That instead of a simple battery swapping demonstration, Elon is going to overshadow that with an announcement of the adoption of a new ground-breaking battery chemistry? :wink:
Larry
I have 2 theories:
#1 Teslas "Swapper" isn't actually removing the battery pack, but plugging into direct DC ports on the rear of the pack (next to where the motor / inverter plugs in), then they've come up with some kind of "Hyper charger" that needs a direct connection to the pack, because the current connector cannot handle the current. They may use some kind of DC battery bank and equipment to dump the charge in very quickly, the robot unplugs the connection and you drive off.
#2 if Tesla does actually have a battery swapping robot, they have something compelling to swap in, and make it worthwhile, such as the new metal air / lithium combo 500 mile range pack.
Btw, I think #1 is more likely, since there is far less mechanical complexity involved, and they are not moving packs around, just electrons.
