Tam
...pretty unlikely they got pulled over...
Couldn't some smart Highway Patrol Officers turn off all their radars/lasers, sneak behind them then suddenly turn the speed detector on at the last minute?
I am surprised that there's no bad publicity this time complaining that you have to wear arctic clothes in a Tesla
So any speculation on what might be possible with the new Roadster? Is that going to be more limited by Law Enforcement than by charging times, more like an ICE?
This trip averaged 56 mph INCLUDING charging, right? Near as I can tell, the slowest leg between Superchargers would have been about 80 mph, with the fastest in the 90's. The Roadster will be faster, likely as efficient, but with faster charging and twice the range.
I see blue flashing lights at 5min33sec into the time-lapse videoDid they get pulled over?
...more like an ICE?
Tesla Model 3 Sets New EV Cannonball Run Record of 50 Hours, 16 Minutes
Yeah but the Model 3 was stock, the ICE that set the record had 2 extra gas tanks on board. I bet the Tesla could do better stuffed full of batteries.ICE time was 28:50 for 2,813.7 miles or 98MPH. Sounds like too hard for EV to catch up!
A sustained 56 mph drive over unlimited distance in an EV circa 2017 is amazing.
I'm having trouble figuring out how it is even possible
After all,
even if they were able to average 1C charging, a minute of downtime gave them 1333 Wh they spent recouping the minute and averaging 56 mph.
Crazy good results from the Model 3.
If you stop every 200 miles for 40 minutes, and average 69mph while actually driving it works out about right to average the 56mph they accomplished.
to be fair, they probably didn't see winter temps from CA to MO or so......looks like they took a mostly southern route, probably for efficiency and weather purposes.True, but that result would require a car efficiency of 5 miles per minute charging, At 69 mph ? In the winter ?
I suppose in the realm of possible, but just barely
I just decided to assume that they were aiming for 40 minute charges to avoid time-wasting taper. With 40 minute charges, that was the way the math worked out... once there's more data we'll see how close I was.True, but that result would require a car efficiency of 5 miles per minute charging, At 69 mph ? In the winter ?
