WilliamG
Hinge Fanatic
Ahem. Due to popular demand…
Thank you, Tesla, for sponsoring this video by giving me a loaner Model 3.
You shouldn’t be driving around so much in the evening. One might expect you to be a burglar or perhaps a drug dealer. Or even trying to sell aftermarket headlight?Ahem. Due to popular demand…
Accelerometers acting as microphones? Wha?Learned something today about ARNR. According to my service invoice:
The Active Noise Canceling system has accelerometers installed on all 4 knuckles of the suspension which act as microphones to produce the inverse phase of the road noise to cancel out the road noise in a physics phenomenon called destructive interference. This system is designed and optimized for stock applications and any kind of aftermarket suspension, wheels or brakes can cause the system to not function as designed. Technician recommends to keep ANC turned off or to put vehicle back to stock.
Great.... So going to get into my edd and get rescheduled possiblyMy order date was 7/15/21 RN1153 and got into my first day of my 2 week EDD and mid day jump end to beginning of the next months to the following month. Sooo close and yet so far again.![]()
Accelerometers on the hinges, you say?!Learned something today about ARNR. According to my service invoice:
You shouldn’t be driving around so much in the evening. One might expect you to be a burglar or perhaps a drug dealer. Or even trying to sell aftermarket headlight?![]()
Interesting. A recent Munro video mentioned those accelerometers. I don't think that mentioned that were used for ANC, maybe they didn't know. Wouldn't actual microphones work better for noise cancellation?Learned something today about ARNR. According to my service invoice:
I think I’d take what one Tesla rep about the knuckles with a fairly hefty grain of salt.Interesting. A recent Munro video mentioned those accelerometers. I don't think that mentioned that were used for ANC, maybe they didn't know. Wouldn't actual microphones work better for noise cancellation?
After I got my new wheels and tires I noticed more noise and I remember a post by WilliamG that said the road noise was worse with ANC turned on so I turned it off and it’s a little better. The problem is ANC defaults to on and I have to manually turn it off.Learned something today about ARNR. According to my service invoice:
Interesting. I’ve had the ARNR turn back on by itself quite a few times, which was definitely annoying. Wonder what is causing it to bug out? Mine was awful with stock tires/wheels…After I got my new wheels and tires I noticed more noise and I remember a post by WilliamG that said the road noise was worse with ANC turned on so I turned it off and it’s a little better. The problem is ANC defaults to on and I have to manually turn it off.
The problem is I don’t exactly know when it turns itself back on. The only way I know it is when I start to hear more than normal road noise and then when I check it, I see that it is on and I have to turn it back off.Interesting. I’ve had the ARNR turn back on by itself quite a few times, which was definitely annoying. Wonder what is causing it to bug out? Mine was awful with stock tires/wheels…
Yep. Same. And the noise is so bad… I’d schedule service. It’s so easy to toggle the ARNR off and on and hear the racket so service should easily be able to reproduce. This was my car with ARNR on… crazy-making…The problem is I don’t exactly know when it turns itself back on. The only way I know it is when I start to hear more than normal road noise and then when I check it, I see that it is on and I have to turn it back off.
For those with non stock wheel tire combinations that want no ANCR you could remove the back panel to your seats and pull the connector to the headrest speakers. With all the posts complaining about this system being quieter when off, brand new with the factory wheels and tires, I wonder if this system works just fine and it is not properly set up at the factory. According to what we know so far, changes to wheels, tires, brakes and suspension offsets the as factory settings. So, is there only one setting from the factory?The problem is I don’t exactly know when it turns itself back on. The only way I know it is when I start to hear more than normal road noise and then when I check it, I see that it is on and I have to turn it back off.
Kind of reminds me of cruising the streets years ago with my 68 Barracuda 340 with it's big cam.Yep. Same. And the noise is so bad… I’d schedule service. It’s so easy to toggle the ARNR off and on and hear the racket so service should easily be able to reproduce. This was my car with ARNR on… crazy-making…
That's painful to listen too, does sound like a cammed out TeslaYep. Same. And the noise is so bad… I’d schedule service. It’s so easy to toggle the ARNR off and on and hear the racket so service should easily be able to reproduce. This was my car with ARNR on… crazy-making…
Good luck! Send picturesDelivery Day today! Wish me luck!
