As far as I know, a pre-Raven and post-Raven S share the same brakes. Those brakes are not up to the Ring - see this post:
Model S to the Nürburgring Next Week! Porsche has solved this issue for the Taycan by putting massive ceramic rotors (bigger than a Porsche 918, a car that can run sub 7s at the Ring) and ten-piston calipers on it.
The reason more people don't complain about the brakes is that in many cases, the pre-Raven goes into limp mode on track before the brakes give out. Anybody that tracks cars regularly knows that once you improve one area of the car to make it go faster, then other areas will often be stressed that weren't previously. If indeed the Raven's speed on track is materially different than a pre-Raven and it doesn't go into limp mode when driven flat out at the Ring, then the brakes will be further stressed and will give out earlier.
