it needs to be a higher end one to get a the dual cable
It really makes you appreciate how Tesla designed their's to use cheap adapters vs buying a new $500 cable.
He said name one, not two...audi etron as well
So this may seem a bit controversial, but now that Tesla is no longer shipping the 14-50 adapters with the UMC / new vehicles, I would like to throw out there that 14-50 is perhaps no longer the logical receptacle to install for home installations.
Here are the benefits of a 6-50 receptacle over a 14-50:
Here are the downsides of a 6-50 over a 14-50:
- Does not require a neutral wire which is an added cost
- Cable is smaller in diameter and more flexible, so easier to install
- Receptacle is less expensive
- Less wires required in the wall box makes for easier installation
Here is a back-of-the-napkin example of a basic installation cost comparison:
- Future EVSEs might not come with a 6-50 receptacle option (though there are J1772 EVSE's that support 6-50 right now)
- You can't use the receptacle for visiting RV's (most EV owners won't care about this)
- Buying the 14-50 adapter from Tesla instead of the 6-50 would allow you to use that 14-50 adapter elsewhere when on the road (and 14-50 is more common these days than 6-50)
Now this assumes basic 6 gauge copper NM cable and at 100 feet (which perhaps is a little longer than the average install?)
The 14-50 comes out to be almost 62% more expensive!
Now, if you are paying a professional to install this, the vast majority of the cost is probably their labor and the delta cost for them to do a 14-50 vs. a 6-50 is not much (6-50 is going to be less stiff so perhaps marginally easier to install).
Am I missing anything here?
What do you think?
What do you think?
This is kind of an interesting discussion, when did they stop shipping the 14-50 adapters with new cars? I took delivery on 4/16, and mine came with one.
The outlet cost appears to be widely variable, but they certainly can be had for less than that. I believe I paid $7.86 at my local home improvement store for my 14-50 outlet. The three wire cable is more expensive for sure, but beyond that I don't see much of an advantage of the 6-50. The Mobile Connector certainly checks for that neutral circuit, though… When testing the wiring my neutral slipped off in the breaker box and the indicator on the Connector turned red and stopped charging. It may not use it, but it certainly wants it to be there for some reason.
Hey Tom, that most certainly is the Leviton that I also had bought and installed. It has been found to be less than appropriate for our needs, overheat and melting potential. I went with the Bryant from Zoro, it cost more but less than the highly recommended Hubbell. Fortunately, the Bryant is also made by Hubbell, so no loss in quality. If you decide to continue with the Leviton, it is recommended to make a routine of checking the connections for looseness.
See this thread: NEMA 14-50 Plug Meltdown / Near Fire
Well, for your own use at home, you can always just buy cable with 3 wires only, and leave out the neutral wire. But you would certainly need to prominently and permanently mark your outlet accordingly. And BTW, I am finding it nice to create for myself a long extension cord that leaves out the neutral wire, AND leaves out the neutral PLUG TERMINAL. This plug will then fit both 14-50 and 14-30 dryer outlets; very handy. Again, prominently marked...That's one way to view it. The other is that the 6-50 is really a better match for EV charging, since no EVSE will ever have mixed 120/240V loads. So unless you plan to use the outlet for something else (e.g. feeding an RV in case the outlet is outside) you're probably wasting money on a 14-50.
No, no, no. You are misunderstanding. Don't ever do this--intentionally installing a mis-wired outlet into your home in violation of National Electric Code. That's all kinds of bad. There are proper official outlet types that are made for only 240V and ground, that only use those three wires. You do not just put a 14-50 outlet on there and omit connecting one of the slots and then put a label on it to indicate that it is installed wrong. Just don't do that or recommend that to anyone, please.Well, for your own use at home, you can always just buy cable with 3 wires only, and leave out the neutral wire. But you would certainly need to prominently and permanently mark your outlet accordingly.
OK, this is another matter entirely, and is fine for people to do, because it's not something installed in your house.And BTW, I am finding it nice to create for myself a long extension cord that leaves out the neutral wire, AND leaves out the neutral PLUG TERMINAL. This plug will then fit both 14-50 and 14-30 dryer outlets; very handy. Again, prominently marked...
Both of my LeafsThat is utter nonsense. Name another EV that comes with a 14-50 plug on its power cord.
What do you think?
OP, you're wrong about why the 14-50 adapter isn't given away for free anymore. Tesla realized they could further enhance corporate profits by selling it separately, just as they do with the 6-50.
What the hell? You just like piling on? Didn't you see that someone already corrected me with that same answer in this very thread back in May? I then admitted that I had not known about that...also back in May. Leave it alone, man.Both of my Leafs
Since this thread got resurrected recently...my thought is if you are going to be so obsessive over installing a 6-50 0ver a 14-50 after buying this car, I don't get the penny pinching so to speak. If you ever need to run power tools or if someone working in your home is doing remodeling work for you, re-landscaping your yard and needing a stone cutter, etc. you'll be glad you put in the 14-50. Probably more times the 14-50 will be used than the 6-50 for welding in one's home.
Thanks for the link. Google search was showing $60+ for an adapter. I have a 14-50 receptacle, but thinking about using this with a ChargePoint Home charger. Local utility is offering $500 rebate to install a charger, but CPH doesn't have a 14-50 plug. :/bingo. Spot on. And if, for some craaaazy reason you need a 6-50, well, here ya go.
https://www.hobartweldshop.com/adap...mpion-elite-champion-10-000-welder-generator/
Electrical work is the one area NOT to cut corners.
As an example, when we installed our outdoor HPWC, our electrician also added a quick-disconnect box. It's not "strictly" required - more of an AHJ rule than a hard-and-fast NEC requirement, but sure sounded like a good idea to me. Better to spend a few bucks and do it right, than cheap out ..... Also makes it much easier to swap out the HPWC for something else if that becomes a thing down the line ...
