New interactive range calculator (now tops at out 70MPH)
Discussion in 'Model S' started by AWDtsla, Jun 24, 2015.
Tags:
  1. AWDtsla
    AWDtsla Active Member
    NE
    Planner is a few pages down here: Model S | Tesla Motors
    This seems a little disingenuous to me. Around here with the top posted limit at 65 MPH It's almost expected to get on the highway and drive at least 80 MPH, or you better get out of the way in the right lanes. This happens even when 55 is posted.
    What happened to driving an electric car without compromises? I want to see what range I have driving 80-85.
  2. kuttakamina
    kuttakamina Member
    DC
    #2 kuttakamina, Jun 24, 2015
    On the other hand, east coast speed limits are 55mph.
    At 90 degrees, AC on (most of the times),
    45mph -
    70D - 346mi
    S85 - 329mi
    85D - 344mi
    P85D - 344mi
    55mph -
    70D - 296mi
    S85 - 290mi
    85D - 300mi
    P85D - 296mi
    60mph -
    70D - 272mi
    S85 - 273mi
    85D - 281mi
    P85D - 274mi
    Even at 70mph, the real range difference between 70D and 85D is only 20 miles.
    Practically speaking on long trips,
    - An 85D will have to stop at every supercharger that the 70D will have to stop at,
    - And the stop will be 5 minutes shorter with 85D
    - And the faster accelaratoin that you'll rarely ever use.
    Y'know, you can keep that bigger battery. I'll keep the 10K.
    And if the bigger frunk is not important to you, why would you ever get a S85!
  3. Max*
    Max* Charging
    NoVa
    Way to threadjack the thread!
    I agree OP, there should be up to 155mph. That's the top speed of the car, right?
    - - - Updated - - -
    The 21" wheels have the least effect (% wise) on the 70D as compared to all the other models.
    - - - Updated - - -
    Not if it's 0F outside and you're doing 70mph. Then it's almost a 50mile difference.
  4. green1
    green1 Active Member
    Calgary, Alberta, Canada
    Normal highway speed limit here is 110km/hr (68mph), common convention around here is to go 10km/hr over the speed limit, which takes us up to 75mph. They just upped the speed limit on a few of the highways in the next province over to 120km/hr (75mph) which makes the expected speed 130km/hr (80mph) (over a high mountain pass at that)
    Why would I want to calculate my range at 70mph (112km/hr) when NOBODY drives that slow on any of those roads?
  5. deonb
    deonb Supporting Member
    Redmond, WA
  6. kuttakamina
    kuttakamina Member
    DC
    Its hit 0F .. ONCE in the last 10 years.
    And I didn't do 70mph then :)
  7. mknox
    mknox Well-Known Member
    Toronto, ON
    This is what the speed limit signs look like in Ontario. Why is it that people see the word "Maximum" and interpret it as "Minimum"???
  8. green1
    Ontario is not all of Canada, and a large portion of the rest of the country has higher speed limits than that posted. As for why people drive over the limit, it is because failing to do so is extremely dangerous and makes you a hazard on the road. The safest speed is always the same speed as everyone else.
    That said, I wish that behaviour would change, I'm all for upping all speed limits by 20km/hr and then setting that to be a true maximum enforced properly. But as long as speed limits remain comically low, often unchanged in many decades despite big improvements in both vehicle and road design, people won't have any respect for them.
  9. AWDtsla
    NE
    Because the posted limit is ridiculously slow, it's for a 60 year old grandmother driving a car made in 1950. It's hard for people to imagine how bad those cars were. You could hit something at 15 mph, flip over burst into flames and kill everyone inside.
  10. robby
    robby Member
    Andover, MA
    Something is wrong with the 70D data here. Raising the outside temp from 70 to 90 with AC on increases the 70D range (while decreasing all the others). That doesn't seem right.
    Also, based on the old data, 0-degree range with heat on @70MPH is ~50 miles more on the 85D than on the 70D. That could easily be the difference between having to SuperCharge and not on ski trips here in the northeast.
    I agree that in most cases the 70D is the best value, but certain commuting habits still make a strong case for the 85D.
  11. mknox
    Toronto, ON
    Wasn't trying to be Ontario-centric... just pointing out that most, if not all speed signs have words like "Maximum" or "Limit" in them.
    I don't necessarily agree. There are also legal Minimum Speeds. Some jurisdictions post them. I believe in Ontario it is defined as something like 30 km/h below the posted Maximum. Transport trucks, RVs, people towing trailers all generally are moving slower than the posted Maximum and are hardly a hazard. Someone driving below the legal Minimum Speed... sure that can be hazardous.
    To bring this back on topic, often I will drive at or below the posted Maximum to extend my electric range. In doing so, lane discipline is very important and I always stay to the right except when passing. What I do find annoying, and dangerous, is that sometimes when I move left to pass a slower vehicle, with every intention of moving back to the right when I'm done, is some idiot will fly up behind me while I'm half way through the pass and drive 6" off my rear bumper. Clearly that's not got anything to do with traffic moving at different speeds, because we both are now moving at exactly the same speed.
    - - - Updated - - -
    North American speed limits were lowered in the 1970's due to the so-called Energy Crisis as a way to improve fuel efficiency. An unintended consequence was that accident and injury rates also declined. As such, when the "Energy Crisis" ended, it was difficult for the politicians to raise the limits back up knowing full well it would lead to more carnage.
  12. SabrToothSqrl
    SabrToothSqrl Active Member
    PA
    ... so take their data, figure out the calculation, and write your own range vs. speed vs. temp calculator, then you can throw in whatever numbers you want.
  13. TexasEV
    TexasEV Well-Known Member
    Austin, TX
    And cars and highways became safer, and there are fewer DWI. Correlation does not equal causation.
    We're not seeing carnage on the road in Texas where speed limits have gone up to 75-85 mph on appropriate highways.
  14. cantdecide
    cantdecide Member
    Boulder, CO
    Wait... Those numbers say that at 45mph the 70D has more range than the 85D? Does not sound right.
  15. Max*
    Max* Charging
    NoVa
    Actually it does. The 70D has better city MPGe than the 85D, whereas the 85D has better highway MPGe.
  16. Sosius
    Sosius a.k.a. Uptown Frunk
    Gulf Coast
    There has probably already been a thread on this somewhere, but I just saw the new range calculator on the Tesla site. It's giving my Model S about 20 more miles than I was expecting (260 vs 240). Does anyone know why this is?
    Thanks
  17. Max*
    Max* Charging
    NoVa
  18. JMG
    JMG Member
    NE Texas
    Hate to say it, but it's just classic salesmanship I would think (kind of like the pricing "after gas savings").
    Say you have a speed demon potential customer who gets on there and cranks it up to 85mph for a "what if" and sees the range drop precipitously, he goes "What?! 1XX miles? Fuhgetaboutit!" However, since it stops at 70 he probably just erroneously infers "Hmm okay, 231 miles at 70mph on 21"...I bet 85mph is only like 225 or something....."
  19. Rifleman
    Rifleman Now owns 2 Model S's!!!
    Harrison Ohio
    No love for us 60 owners :(
  20. cantdecide
    cantdecide Member
    Boulder, CO
    When you take a car and only add more battery I would expect mpge to drop but range to improve at all speeds... We aren't talking dual motor differences or anything... Just more battery.
