Correction it’s Sat 5th I’m missing too.Readings back online (without me doing anything) but Sunday’s readings still missing. I guess I can cope with a missing day.
I’m exactly the sameCorrection it’s Sat 5th I’m missing too.
SMETS1 Secure Meter.
Could you double check 'In Day Adjustment' calc too: Isn't “Baselined Entity Metered Volume” the actual volumes from the day of the Savings Session and “Unadjusted Baseline Value” the 10 day baseline? i.e. In Day Adjustment = Sum(Today's half-hour n - Baseline half-hour n) / 6 : 1…n…6In Day Adjustment = ∑j (Baselined Entity Metered Volume – Unadjusted Baseline Value) / 6
Q: Could consumers moving demand in anticipation of an event influence the in-day baseline readjustment? A: We acknowledge that this is a risk. This is another one of the factors for the DFS being an enhanced action rather than an everyday action. We hope that the use of an industry agreed baseline methodology with the agreed sample size will be sufficient to avoid such behaviour.
3. Octopus Energy reserves the right to cancel or amend the Service and/or the Rules without prior notice. Any changes will be posted on our website.
Thanks for the response - yeah my question is should I trust it to charge, given that I don’t see a schedule in the app at 11pm.So your question really seems to be whether you should trust IO. Since it doesn't need your agreement on the plan it proposes, yes, I think it's reasonably safe to assume it will charge. I've never had it not do so.
I've been running IO for a few months and not had a problem, but equally a) I set the car to try at 23:45, so if it falls over altogether it'll still get some juice and b) if it didn't charge, 99% of the time it wouldn't be the end of the world.I admit I’ve not had a problem yet (in 6 weeks of ownership) and don’t always check. However when you do check it would be reassuring to see the schedule and not have inconsistent behaviour!
Yes, I had similar issues last week that I posted on this thread.I’ve been having issues with the IO schedule being generated this week.
When i plug in at around 8pm the session hasn’t shown in Octopus app by 11pm.
As I didn’t want to risk being too low for a long journey the next day I started the charge manually from Tesla app at 11pm (figuring it was only going to be 30mins peak rate).
Reviewing the charge the next day (via Tessie app) it looks like the charge was then stopped 10mins later and restarted a few hours later.
Anyone else with similar experience? Would it have been ok had I not started the charge manually? I’ve done this twice now as I didn’t want to risk it.
They do not have intermittent issues.Yes, I had similar issues last week that I posted on this thread.
Couple hours for the schedule to appear, a lot of stop & go charges during the night.
Either Octopus is having some intermittent issues, or I suspect there are some days where they don't want you to charge, even at night and are using a bit of their discretionary power to suspend charges bases on your previous patterns... Will definitely escalate this to them if it continues but after months of flawless charges, I have some reservations lately...
That would explain why it takes several hours to pull up a charge schedule, although I've read that after 5pm it's not supposed to take that long even post 31-Aug update, but that does not explain why it randomly disconnect the car mid-charge between 23.30 & 5.30...They do not have intermittent issues.
The back end has been re-configured to poll the Tesla API less frequently in order to stop the car being kept awake. It's nothing more conspiratorial than that. This has brought it's own niggles but it unless they can find some happy medium it's what we need to put up with.
That's by design. Although charging slots are nominally allocated HH, Octopus actually have finer control and can pause a charge mid slot if it helps with grid balancing.but that does not explain why it randomly disconnect the car mid-charge between 23.30 & 5.30...
I have no issues with that as long as it brings my car to the target level I set before. If it undercharges when I wake up in the morning then I'm not happy.That's by design. Although charging slots are nominally allocated HH, Octopus actually have finer control and can pause a charge mid slot if it helps with grid balancing.
In fact, although IO is sold as an amorphous service, depending on which integration you have Octopus can do all sorts of things. Those on the Ohme charger beta can also have the current dynamically altered, although this doesn't happen through the Tesla integration.
OK, I won't.don't tell me the 1 min, 3 mins, and 10 mins pauses helped with the grid.
On the long run (based on the last few months/year) it's still way more expensive to run assuming a 50/50 split between house consumption and EV charging.Agile prices went negative last night and zero the night before. I’m guessing due to the excessive wind we’ve been having. Anyone been looking at it?
