Recirculation can only be controlled from the car touchscreen. There's currently no way to do "X for Y minutes" from the app, but that's definitely a neat idea.Is it possible to create an automation to turn off recirculate and run the HVAC for 5 minutes after the car is parked?
You can keep using it by using Google's IFTTT integration. Migration guide here.Just got notified by my google home mini that Tessie won't be available from June 16th onwards....apparently google are shutting down the 3rd party integration for routines and such. Thanks google....thats REALLY unhelpful.
James, you have any contingency plans for this at all? Hopeful that you do.
just checking in...Is the watch app (BT control) still on track to be released in the coming days?I'd love to have it out within the next month.
When Tessie is letting your car go to sleep (whenever you park and the car goes idle), it relies on a car subsystem to communicate when drives start up again. But, only one thing can use that system at a time. So when you're running multiple trackers it will inevitably cause missed drives with one of them since they didn't know that driving started. You'd fix that behavior by using one and then restarting the car for good measure (just in case that system got stuck, which is a car bug that happens sometimes.)I have had one or two drives not appear on Tessie, but they do show up on another metrics site I use. Is there a particular cause/reason on how to look into this?
Hi James,It uses an average because single data points fluctuate.
The reason for the 82.1 <> 77.8 initial capacity discrepancy is Tesla recently reclassified some of the energy efficiency labels in the firmware, and now there are two different batteries using the same internal label. You'd either have the 82.1 pack or the 77.8 pack.Hi James,
Could you check out the following thread, there seems to be some discrepancies in what Tessie is calling the initial capacity of the pack and the degradation calculations, which is resulting in underestimating the degradation of vehicles and the fleet average.
Battery Degradation Year 1
As I close in on a year of ownership and just over 22k miles, this is the degradation report from Tessie and Recurrent.teslamotorsclub.com
For sure. It can definitely be easier depending on if you need to scan through the list or not. I tested this awhile back, and basically, reading an individual drive is easier with the first layout but scanning is easier with the second layout. I'll revisit this again.Hi James,
Thanks again for this excellent app! I was looking through the "Drives" screen and had an idea. I typically view the drives in chronological order, with the most recent drive at the top (the default sorting, I think). Anyway, I sometimes have issues quickly determining which drive is which, and I think it is because the origin (FROM) is on top and the destination (TO) is on bottom. That results in the following scenario for a hypothetical day of driving:
FROM C
TO D
FROM B
TO C
FROM A
TO B
It might make things easier to read if the destination is moved to the top. That way, the destination on a drive is directly next to the origin on the following drive, since they are the same place (or should be). The same example becomes:
TO D
FROM C
TO C
FROM B
TO B
FROM A
Not sure what everyone's preference is, but I thought I'd share my suggestion to get your thoughts. This probably only applies to the newest to oldest sort order. Maybe a user-configured setting specific to this sorting?
Thanks again!
It's a quirk from the limitation of how many points can be shown without devices crashing. The longer the time period, the less granular the data points, so longer time periods might not show everything. It's also exacerbated due to data being extrapolated from the nearest data point when the car is asleep. There are some special algorithms to improve this that I plan on implementing in the not too distant future.Noticed recently that the 30 day plots on the Activities screen are messed up and showing incorrect data. Changing to last 7 days shows correct data.
