I could tell that he was going to hit the pickup, before it hit, I guess I am the only one here that is not blind or blinded by wanting to make Tesla responsible for this driver's actions.
How will this crash scenario be prevented in future upgrade/improvement?
We've got the video right there. Please cite the time mark at which you make this observation and what, specifically, you observe at that point. Thanks.I could tell that he was going to hit the pickup, before it hit, I guess I am the only one here that is not blind or blinded by wanting to make Tesla responsible for this driver's actions.
It is nonproductive to assign blame to owners or Tesla when there is already a waiver saying that an owner is responsible when Autopilot (self parking is a subset of Autopilot) is in use.
I'm not trying to be antagonistic, but you didn't answer my question. The reason I asked is that if you are encountering these same circumstances and not having these problems then you might be able to share with us your "secret" to making it work, which is what we
all ultimately want (not to tear down Tesla). Btw, the ("perceived") problems with parallel auto-park go way beyond the topic of this particular thread.
The hitting things issue is, to my knowledge, an extremely rare occurrence. It is not the primary basis for my "bridge too far" claim. ThatI'm not doing anything special or using any tricks. The car, to date, has fit into every spot it said it could without hitting the curb or the surrounding vehicles.
Jeff
I disagree completely, I've used it well over 100 times without fail, without issue, without even a close call in tight spaces. I'm not saying it's perfect, but to say its "a bridge too far for Tesla" is absurd.
Jeff
Will give the ownership line a call to have the logs reviewed for sensor faults.
Bleh.
RHD cars need to park left-side in UK, Australia and Japan, etc. Needs to operate as software that can "flip the circumstances" and work the same whether left or right. In computer programming, it can come down to a negative sign on a formula rather than positive when the car location is mapped out on the X and Y axis. If anyone has ever "programmed Pong" in any computer language and worked on X/Y coordinates, you know what I mean.
If you really wanted to be a snot about it you could ask them to tell you something from the logs that only you would know (without actually looking at the logs), such as what date some unusual event occurred on.Let me know how that goes. It took me a month and an uncountable number of calls, reports, emails, and various other methods to get Tesla to actually inspect the logs. In that process they SAID they inspected them but did not actually expect them. Make sure you get a legitimate answer and keep pressing until they actually inspect your logs and give you specifics.
This is exactly the problem, Jeff. When your autopilot fails and actually causes damage I'm confident you will feel differently. However, it is easy to say "this hasn't happened to me yet therefore...."
The autopark and at times autopilot act in a way which doesn't allow human intervention to occur soon enough to prevent damage. In that scenario, where no reasonable driver could be expected to intervene soon enough to prevent that damage then no amount of disclaimers will protect Tesla and the long list of disclaimers they already have essentially say, "this doesn't work as intended." The only possible way to not be liable for Tesla's software and hardware faults is to simply not use their systems. Otherwise, they will abruptly place the blame on you saying "we told them it doesn't work!"
Doesn't that seem kind of strange to you?
The autopark and at times autopilot act in a way which doesn't allow human intervention to occur soon enough to prevent damage."
claim is based on the large, growing, and ill-defined set of circumstances in which it simply doesn't work at all (as I said above,
certainly the preferred failure mode, but...). So do you find you can routinely use it on streets with traffic behind you? For you does
it routinely recognize non-square curbs? Does it never claim to see a parking spot in the middle of traffic, such as at a stop light?
After an owner who didn't know that he activated the summoning and left the car unsupervised and it crashed into the top front a tall semi-trailer bed,
Tesla revised the procedure to include another acknowledgement step to make sure driver is aware of summoning and is to hang around to babysit the system to make sure an owner would intervene to stop the car from crashing in the same scenario.
Could it be that Tesla has problems of crashing onto taller obstacles such as the mark of bumper damage is just above the sensor in this parallel parking case?
Should more sensors be added, and may be at a higher locations to detect taller obstacles such as pickup and semi trucks?
Trailer hitches concern me.I'm thinking if that plastic step thingy wasn't there it probably wouldn't have happened. My take away is avoid PA when pickups are there but out of curiosity has anyone else had an issue using this feature when pickups or other higher vehicles are in the space ahead or behind?
FYI just took delivery of 60D and except for the test drive haven't used parking assist yet.
