ZenRockGarden
Living the SoCal dream!
Mild weather certainly helps both on battery temp and use of interior climate controls.
This is the key point. By not preconditioning, she is forcing the car to drive, heat the battery and heat the cabin all at once. Driving an EV with a dead-cold battery is very inefficient. I always precon, even though the car sits in my garage. I'd give up the (maybe) 1% it costs me to have a much more efficient drive.She parks outside and must not have preconditioned before leaving. By the time she got home car was at 36%.
Difficult use case? There are thousands of Teslas and other EVs in Quebec where freezing is the name of the game and most don't have a garage. Nordic European countries thrive on EVs and they also see multiple months of freezing. It's not a problem.
EDIT: Freezing is a problem for ICE as well. They don't start, they take 15 minutes to heat up, etc. Nothing's perfect.
Good luck with that! Seems like a new one posted almost every day.... But the manufacturers do need to do a better job of publicizing the difference between warm and cold weather range. I suspect they won't do that until forced to by some regulation, just like they aren't required to provide 'real world range' and instead are using outdated EPA tests (certainly not their fault - they have to use what they are given). Just like ICE cars are required to provide city, highway and combined fuel mileage ratings, EV's should have to display averages for warm/cold ranges.Just trying to reduce the rate of "This stupid car can only go 150 miles, not the 300 I was promised!" posts
It’s a fair criticism though. ICE cars do not halve in range in any weather.Just trying to reduce the rate of "This stupid car can only go 150 miles, not the 300 I was promised!" posts
It's because there are two very separate concepts that work in opposite ways that people try to smoosh together in simplifying whether EVs are "good" or "bad" in cold weather.Difficult use case? There are thousands of Teslas and other EVs in Quebec where freezing is the name of the game and most don't have a garage. Nordic European countries thrive on EVs and they also see multiple months of freezing. It's not a problem.
Now that the Tesla Model 3, Model Y support blended friction braking when regenerative braking is reduced or unavailable the benefit of warming the battery prior to driving are so that the battery can output more power on demand. If you drive with the blue snowflake the maximum available power is reduced; you may not notice the reduced power if you don't test the 0 to 60 time when the blue snowflake is visible.Preconditioning the battery really isn’t necessary, and it won’t improve driving efficiency aside from enabling regen. The added regen will (almost) never make up for the energy used to heat the battery.
Battery heating while on shore power can be beneficial for driver experience (regen). Battery preconditioning from shore power is most effective when it’s used to bring the pack up to temperature prior to seeing out on a road trip where you’ll be DC fast charging. That heat would need to be added by expending battery power while en route to the supercharger, thus doing it from shore power improves range on the first leg of a road trip. It should be noted that preconditioning only warms the pack to about 10°C, so it will still need to precondition for supercharging even if you warmed it up on shore power.
If you monitor your consumption from the wall, you’ll find that it is more efficient overall to not precondition longer than necessary to heat the cabin.
It’s also worth noting that 3/Y will not actively heat the battery just by getting in and driving. You must either precondition or navigate to a supercharger. Not sure about S/X since I don’t have one of those.
