Real Tesla drivers always back into parking spots.![]()
And if they use Automatic Perpendicular Parking, they do it reeeeally slow.
Let's say for instance the car was parked with the front bumper against a wall (so you couldn't get to the frunk emergency release mechanism) and the car was plugged into a destination charger with a wired HPC that couldn't be unplugged from the wall...
A little more edge than that. Unless the plug needs a lot of clearance to come out, from side shots it looks like you still get a little clearance in front of the port even if placed the nose physically touching straight into a vehicle wall.Let's say for instance the car was parked with the front bumper against a wall (so you couldn't get to the frunk emergency release mechanism) and the car was plugged into a destination charger with a wired HPC that couldn't be unplugged from the wall...
Perhaps an unlikely situation, but I could see it happen at a hotel destination charger, or in someone's cramped garage.
I think you'd need to keep the external power source connected, unless the problem with the 12V was corrected by the reboot?If the 12V system is powered up via external supply, shouldn't the car be able to switch on the high voltage system and move under its own power?
So, if your 12V is completely dead, and a plug is locked in the charging socket, is there a way to get the trunk hatch open to release the charge port lock pin?
Apparently there is a charge port manual release inside the car, but if the 12V is dead, and you can't get to the frunk to power the vehicle back up, how would you get to the charge port release?
My daughter had a VW Jetta (about year 2000). The battery died and the locks were electric so wouldn't open. No way to get to the battery to jump it. Tow to the dealer where they did something (I forget) to get access.Thanks!
Most (virtually all?) other vehicles which have systems like Smart Key System (Toyota parlance) or Intelligent Key (Nissan parlance) include a mechanical key in the fob and at least 1 key hole to allow unlocking of the door if the fob dies, or fob battery or 12 volt battery dies.
Also, it is absurd that Teslas lock their connector to their car during L1 and L2 AC charging and AFAIK, keep it locked w/o providing an option to the driver to either not lock or auto-unlock when done. It causes extra complications and need for coordination w/Tesla folks at my work who share the HPWCs we have.
Most other vehicles w/J1772 inlets except for a few current offenders like (some?) Kia Soul EV, some VW e-Golfs and the BMW 3-series PHEV either don't have any charging lock or give the driver a choice as to whether to lock, don't lock or unlock when done or just unlock when finished.
I'll take the DC-DC. Bum 12V second choiceWe can take bets now:
- a blown fuse
- a fault (broken component within) whatever model 3 calls its DC-DC converter
- 12v battery
- poor connector or bad ground
Wow - 2 weeks in and already unresponsive!? Hopefully its a quick fix like a faulty 12v, but man, the 3 was going to be our only vehicle other than my bicycle. No way my wife would've tolerated this preventing her from getting around on a weekend, even if it were a one-off. Ugh, I can almost hear "your stupid Tesla won't start!" from our downstairs garage...
Yep! I really can't figure out how she accomplished it, especially more than once (all before we were married)! I hate buying gas, but never let our tank get below 1/4 based on her experiences.Was it you who posted that their wife has run out of gas on the highway a few times though? Stuff happens to cars. Kind of worse when it's your fault.
Ok, I couldn't resist and I pulled the dongle in the trunk and...drumroll...it unlocked the charge cable!! Of course this is only helpful if you can gain entry into the trunk which is hard with no 12V power
Yes, it just needs enough power to close the high-voltage connection. The problem is whether the 12v will retain enough power.
Since there’s no alternator, I’m curious if the 12v system can fail while driving or the 12v is powered off the main battery when it’s on?
I think they have included a trickle charger in the new Model S/Xes which prevents the deep cycling from happening. Tbh I would have used a deep cycle battery or just gone to a lithium 12v battery but im sure there is some issue which prevents this being the optimal solution.
Use a coat hanger(1), pull front door's handle, .
Few years back, I 'bricked' my Porsche trying to upload new engine map.What would you call an ICE vehicle if it quit working and needed service?
