diamond.g
Out of curiosity, with respect to the Google Maps API issue, has anyone seen the same problem with Audi A4's? They have that nice IC with Google Maps on it, and would/should of had the same issue right?
Ah. I did find a blurb that indicates they can update the service without notifying you remotely. But I am not sure if the car talks to Google directly or if it gets translated though Audis servers.Considering that there are likely millions of websites using google maps API (including several of my own), and I have yet to see any broken due to the supposed change, I would certainly not expect that Audi would have been affected either.
Whatever this is, it seems to be Tesla specific in it's effect.
Car definitely uses Google's Voice recognition API...
Code:#!/bin/bash gst-launch -v \ alsasrc num-buffers=600 device=tdm1_slot_12_rec \! \ audio/x-raw-int,rate=8000,channels=1,width=16 \! \ amrnbenc \! \ filesink location=/tmp/vrcap.amr curl \ "http://www.google.com/speech-api/v1/recognize?lang=en-us&client=xxxxxxxxxxxxxxxxxxx" \ --header "Content-Type: audio/amr; rate=8000" \ --data-binary @/tmp/vrcap.amr \ -o /tmp/vrcap.dat sed -e 's/.*utterance":"\([^"]*\).*/\1/' </tmp/vrcap.dat >/tmp/vrcap.txt
Edit: This script is actually depreciated (Google disabled API v1 at some point), and has since been incorporated into the car software with Google's latest API... but still uses Google.
Also, this has happened before. In April 2013 a backward-incompatible change was made to the Google Voice API, causing it to not work with Tesla firmware 4.2 and earlier (voice commands were a new feature in 4.0). The fix was apparently in 4.4 or later, based on the dates of the releases in the firmware wiki.
That seems really incomplete.There is no fallback on the centre screen, however there do appear to be some cached areas of the map (the area around my house for example still displays, but only at certain zoom levels.
There are however 2 different mapping systems in the car, and the onboard navigation continues to work properly displaying the usual mapping on the dash. It even draws the route line on the centre screen, only without the map behind it.
I hesitate to say so with the overall tone of this thread to start with, but "really incomplete" describes a lot of Tesla software.That seems really incomplete.
What's funny is that people over at the 7.1 thread are driving miles and miles to get to a Tesla geofence just to trigger the latest and presumably greatest update and here you and a few others are trying so hard to avoid it. It's such a dichotomy of positions. I don't mean this to cast any doubt on your view as its been consistent for as long as I've known you. It's just such a striking difference.I hesitate to say so with the overall tone of this thread to start with, but "really incomplete" describes a lot of Tesla software.
Is there anything good in the update?What's funny is that people over at the 7.1 thread are driving miles and miles to get to a Tesla geofence just to trigger the latest and presumably greatest update and here you and a few others are trying so hard to avoid it.
Theory is if you're within a particular Tesla Service Center geofenced area, you will get a firmware update assuming it is available for your VIN.Is there anything good in the update?
And what is this Tesla geofence that you're talking about?
I agree fully that this is possible, even likely. That doesn't absolve Tesla of their obligations to not remove or limit previously delivered functionality on my vehicle when they fix it.IME it can happen like this (sorry if this is Granny + Sucking Eggs):
I build an API interface. I am confident it is "just like the DOCs say it should be"
I test it. Once it is all working just fine I "deploy it".
Then the Vendor updates something, and only then do I discover that I didn't actually implement it the way the Vendor intended. The DOCs were wrong, or my interpretation of the DOCs was wrong, or I just plain got it wrong ... but I also got lucky that in all the test use-cases it worked (and presumably no Customer complaints, at that time, either).
So now it is bust ... so I set about fixing it and, let's assume, I am only bothering to do that in my latest Patch-Release.
So could be Tesla-only, and Audi et al are not effected.
Well the thing is this situation is not that straight forward. If it was a case where the API broke and Tesla has "ended support" (meaning no updates for your car anymore) they may have broken some obligations. However, if the fix was in a later version (that is tied with feature changes), I'm not sure if the manufacturer is obligated to release an independent patch to fix it on older versions.I agree fully that this is possible, even likely. That doesn't absolve Tesla of their obligations to not remove or limit previously delivered functionality on my vehicle when they fix it.
Tesla's mistake is not in deploying software updates to fix things, or in relying on 3rd party APIs which can change. Their mistake was in tying those same fixes to feature removals.
If the car was out of warranty, then it might be my problem rather than theirs, but the warranty said they'll repair what breaks (with no exclusion for API calls). Meanwhile nothing I signed at any time in the purchasing process or since has given Tesla the right to remove or limit any functionality on the car. They've dug this hole themselves, and they can dig themselves out of it again.
Speculation but I turned on Dolby in the UHFS and it sounds great for the first time. It could also be my imagination since I saw that module was updated in this release so it could be a little confirmation bias.Cool thanks, I'm not in a rush to get a random bug patch. It'll come whenever it comes. Now if you were to tell me that they fixed nav, or added some cool features, I might make my way over to the Tesla store
Anyways, sorry for hijacking green1.
