I think you are confusing AC vs DC charging.I have read that it would be much simpler to make an adapter for this, since the CCS protocol is more compatible with Tesla signalling, unlike how complicated CHAdeMO was to adapt. Hopefully that would make it cheaper. I think the main issue right now is lack of usefulness. The number of CCS plug out there is tiny.
Heh. Uh, no, I'm not confusing AC and DC. But I was just repeating what I had read/heard from other sources--that Tesla's DC signaling was much more like CCS than CHAdeMO. Perhaps the sources I read were not right; I don't know for sure.I think you are confusing AC vs DC charging.
An adapter between Tesla and J1772 AC charging is trivial because the pins and protocols are identical except for the physical plug design.
An adapter between Tesla and CCS is much more involved. CCS DC charging is the effectively the same regardless of USA type 1 CCS or European type 2 CCS plug format. The signaling protocols and messages are the same between the two CCS DC plug designs, I'm pretty sure.
Tesla's DC protocols are actually closer to CHAdeMO since they seem to use similar, but perhaps not identical, signaling that is based on the so-called CAN bus design that is typically used to network together internal computers and components even within conventional cars. However, Tesla does not seem to use the same CHAdeMO messaging between the car and the DC charger on top of CAN.
The CCS uses a completely different signaling system for DC charging called PLC and sends messages on that data transmission layer using the same tcp/ip protocols that the Internet is based on. The actual messages sent between the car and the DC charger are unique to CCS.
The CCS is much more complex than CHAdeMO because the signal control for CCS is AC, requiring a new communications process, whereas the CHAdeMO uses the CANbus, so is compatible without major changes.First off, just to clarify, that picture you have attached is the European version of the CCS plug, with the Type 2 (Mennekes) on top. The North America version has a Type 1 (J1772) on top.
We can be sure it will happen, the question is when. Tesla is a full member of CharIN and alreadfy supports the Mennekes+ for European Teslas. They will certainly not make an adapter for NA until they figure out the electrical modifications required and can be assured of enough owner interest to justofy teh non-trivial development needed. My guess is that they'll do it as soon as CCS becomes more widely used and the power goes up. That should happen in a couple of years as more European electric cars begin to arrive in North America.Absolutely!
Giving Tesla owners, and prospective owners, more places to charge can only benefit the company.
Interesting. I'd heard the same as the others: that CCS was built on the signalling protocol standardized by J1772, with extensions provided to control the rate of charge and charging capacity of the DC pins. Really unusual that they'd tack DC onto J1772 and completely change the communication protocol.I think you are confusing AC vs DC charging.
Tesla does already support it via Full Membership in CharIN. BTW, although SAE J1772 is the CCS core in North America it is the Mennekes 2 in Europe, the base connector for European Tesla Superchargers. Tesla uses a proprietary pin modification to use for Superchargers. The Tesla connected there can be used for other Mennekes 2 charging with adapters, but adapters are need in those areas that used different phases than is typical. I'll skip the details, they're covered elsewhere in excruciating detail. However, once there are CCS EV's that need fast charging CCS can easily be upgraded to existing Supercharger speeds. That will be around 2020 as MB and VW Group begin to deliver high volumes of EV's in NA. BMW might be in that group too, depending on internal debates now happening.IIRC, there are already 120kWh CCS prototype stations.
Opens 120 kW EV charger to the public | Arctic Roads
The only way 120kW CCS is going to spread quickly is if Tesla supports it. There are no 120kW capable CCS cars.
It is odd that the higher CCS power handling standard has been so slow, probably because only Tesla might use it today. In the meantime Norway will be ready for all those MW, VW Group, etc that will come beginning in 2020 or so. I cannot wait.There are a couple of these 120 kW units here in Norway. The problem is that neither the Chademo or the CCS connector is capable of handling full power. The only benefit is that a Chademo and CCS car can charge at the same time. The only way to make a single car charge at maximum rate is to add a Tesla connector to it.
around here they are installing chademo and CCS at the same time as paired stations
If you have Chademo already why bother with CCS?
Whatever reason you can think of becomes less and less important as superchargers and HPWC cover more and more of the landscape.
* Supercharger is better than
* HPWC is better than
* Chademo is faster than
* random L2 EVSE is better than
* random L1 EVSE
and those are all over the place. I don't see why we need to add CCS to the mix.
I put up with Chademo as a necesarry emergency evil option but every chademo around me is insanely overpriced.
I charge at home for less than half the cost of gasoline. If I charge on Chademo around here they charge 20-50 times that rate (the less you need the more onerous the per charge fee is).
He clarified later on in another post. His "better than" is taking into account of ease of use, convenience, cost, and availability. Speed is just one factor.If my understanding is correct, your ordering is wrong.
I think it is: Supercharger > CCS > Chademo(50kw per nissan) > HPWC > L2 > L1
Basically, it looks like CCS is going to be the final winner in the nationwide fast charging network. Pity, since the Tesla connector is so much more elegent.
