polyphonic54
No issues with braking here (Model 3 Performance [w/Performance upgrades]).
Yeah you have bigger brakes and arguably the best summer tire made, Michelin Pilot Sport 4S.
The advantage of capturing every ~ 24 feet is that you can trend your vehicle speed.Well the original footage frame rate 36fps is not high enough to capture a precise 24 ft. I think averaging over a period of time is more accurate.
But I made a rough calculation though. It's about 15 frames per line, which makes 24 / (15 / 36) = 57.6 ft/s = 39.2mph
Way too fast for wet road conditions. No experience driver?You appear to be the fastest car on the road. That alone is pretty damaging..
I have been thinking about this being a possibility. The OP was at fault clearly for not stopping at time but I think he could have been caught off guard by this and the bad performing MXM4 tires on wet roads. The ABS noises and tire noises the OP mentioned points to the car functioning properly.Don't know the temperature, but it sounded like the OP was anticipating effective regen braking first. In my experience, regen braking is highly variable, at least in colder temperatures. So as a new Tesla driver, one has to be extra cautious until you get to "know the car" and in this case, its braking systems. Certainly before that kind of expectation to brake from a fairly high speed. Under the video conditions, I would have jammed on the real brakes and not trusted any regen braking.
Checked underground weather report, it was 53F at that hour.I have been thinking about this being a possibility. The OP was at fault clearly for not stopping at time but I think he could have been caught off guard by this and the bad performing MXM4 tires on wet roads. The ABS noises and tire noises the OP mentioned points to the car functioning properly.
And OP mentions the temp was between 50 and 70? I suggest use something like weather underground historical weather and compare to the time/date of the accident and see what the temp really was.
Do you have any rear footage that shows when your brake lights come on?
OP cut it too close and lost and needs to own it. Tesla is not going to find anything wrong with the car.
I didn't think you would see brake lights but thought maybe a car could have been behind you and reflected them back or something. Regen on a car that has set out in 53 F is a lot different than 70 F. I was shocked at first because I thought regen was lost only when it got down in the 30s.Checked underground weather report, it was 53F at that hour.
And I can't see brake lights from rear camera.
Most people use AutoPilot. AutoPilot would have prevented the crash. People forget that the moment you use the brakes, you lose AutoPilot.Use regen to brake is how most people drive a Tesla, right?
For me, I'd typically use regen first and then apply brake when speed is lower than about 15mph to come to a full stop. I might have overestimated the power of regen under that road condition.
And 50mph sounds way too fast. If I were at 50, other cars were also speeding. Don't know if there's any way to infer speed from video.
There are screen shots of Tesla Service screens showing that the car tracks the brake usage, and if it has not occurred in a set period of time? the car will use physical brakes instead of regeneration braking to clean off the rotors.You didn't read the article.
"While every Model 3 currently being produced gets driven on a track, Tesla doesn't expect that policy to continue either. Once the assembly process becomes a known quantity, with inefficiencies and errors ironed out, the average quality of the vehicles will go up, meaning there will be less likely to be wrong with any vehicle that rolls off the line. At that point, Tesla will change over to the same spot checking policy that it uses on Model S and Model X, both of which are by now well established in terms of manufacturing."
It's not happening now, at least not to UK cars I can assure you.
Where's the PM information?
Ah there's no car close behind me and I can't see any reflection due to bright daylight...sadI didn't think you would see brake lights but thought maybe a car could have been behind you and reflected them back or something. Regen on a car that has set out in 53 F is a lot different than 70 F. I was shocked at first because I thought regen was lost only when it got down in the 30s.
Around now, it is jumping around from 20degs to 40degs. And under such conditions and needing to stop, I would immediately take my foot of the accelerator and start real braking. I would try to judge (very quickly!) if regen is doing enough and if not get aggressive with the real brakes. In this winter, regen is hit or miss. Often I try to give it a chance and find it is doing almost nothing, at least for 10-20 car lengths. Nearly every drive/trip, I have to first "discover" how much regen I have, say the first 10mins of the drive, which in many instances is the entire duration of the trip.How to use regeneration braking safely? For example, should one start regeneration braking early than one would use regular break. Do you think using regeneration braking may increase the chance of accident as one may misuse it?
Some posts here seem to be blaming the stock tires. I really don't find them that bad at least for such a simple task as facilitate brakes to work as expected. So I doubt the tires are the true issue here. They don't skid for me under typical everyday conditions. I'm fairly certain that if the OP had jammed on the brakes, his car would have come to a screeching stop in fairly short order. But he never did...
That's nonsense. The car won't apply the brakes itself to slow instead of regen. You have to press the brake pedal to apply the brakes other than when the car goes into hold mode. Even 'drying mode' will only cause the pads to lightly contact the rotors to clear them of water.Most people use AutoPilot. AutoPilot would have prevented the crash. People forget that the moment you use the brakes, you lose AutoPilot.
1) You've never experienced the car applying brakes while on Autopilot?That's nonsense. The car won't apply the brakes itself to slow instead of regen. You have to press the brake pedal to apply the brakes other than when the car goes into hold mode. Even 'drying mode' will only cause the pads to lightly contact the rotors to clear them of water.
1) I don't use autopilot so I've no idea1) You've never experienced the car applying brakes while on Autopilot?
2) Why is there a CANBUS signal called "Brake Disc Wipe Request"?
Not to mention it was cold. Cold rubber isn't as grippy. Cold brakes aren't as responsive.The tires are like a 3rd order factor here. Water (bringing up grease) and slope is the main thing.
