Well, according to
Chinese owner's manual of the MY, the
ground clearance is 15 mm (almost 2/3") lower on the MYP. The
"ride" or "coil" height are 17mm front and 16mm rear lower for MYP.
Kinda splitting hairs here I guess.
For the rear, the suspension parts themselves is actually even shorter, because the factory rear tires are bigger than the front, adding almost 7mm of sidewall. So, 16 + 7 is 23mm, or just about an inch. Can't say I know how it plays into all the dynamics of spirited driving, but I'd guess at the very least, the rear is gonna be stiffer.
That makes for odd changes to the "rake" of the car. From LR to P with factory wheels/tires, it gains slightly more positive rake. The front points down more, because the rear didn't drop as much (-17 front vs -16 mm rear height, so miniscule difference). But if you then put on a square wheel/tire setup it actually becomes less positively raked than the LR as the rear will drop an additional 7mm (-17 vs -23, does it become negatively raked?).
Wait, going square means the motors now spin 1:1 (front:rear) while it was different with the staggered wheels. Hum... what does that do to the computer?
On a side note, the China version of the manual is more informative than the US version. It has some
motor specs (outdated?) and alignment values.
