AlanSubie4Life
Efficiency Obsessed Member
Overall don’t quibble with your point but the data in this table is garbage. Source can be put in garbage bin. Your car was ~78kWh (zero debate on this one).For comparison, here's the battery size, range and efficiency of all tesla's models:
Battery Range efficiency 2020 Model Y (my car) 75 kWh 315 mi 238 Wh/mi 2022 Model Y 81 kWh 330 mi 245 Wh/mi 2022 Model S 95 kWh 405 mi 234 Wh/mi 2022 Model X 100 kWh 348 mi 287 Wh/mi 2022 Model 3 (standard) 60 kWh 303 mi 198 Wh/mi
The model 3 is the most efficient model but it's also 1000 lbs lighter than the Model Y. Why would you think the Y would be more efficient?
Model 3 RWD range is not correct. Should be 272mi.
Did not check Model S/X.
