If you fast charge, Tesla will permanently throttle charging
Discussion in 'Model S: Battery & Charging' started by Naonak, May 4, 2017.
  1. Evbwcaer
    Evbwcaer Member
    Minnesota
    If this information is true, I actually appreciate it, although reluctantly.
    A 90kw cap, vs. a 115kw cap, means very little in terms of charge time, possibly excepting the 100kwh.
    You're charging about 20% slower for about 30% of the charge time....a trade worth making to protect the battery, in my opinion.
    On a 100 minute charge, you are looking at about 6 minutes extra. Denser Supercharger placement wipes this concern away.
    Tesla should publish this info if true regardless.
    • Like x 5
    • Informative x 2
  2. AnxietyRanger
    AnxietyRanger Well-Known Member
    EU
    Outside of this being total fake, or the tech confusing the customer's issue with the Ludicrous counter/limiters, the story is awfully specific to be someone just not knowing what they are saying.
    Also, the Ludicrous limiters came with 8.0. Could this also have come with a late firmware and thus new to many?
  3. SmartElectric
    SmartElectric Active Member
    Toronto,Canada
    First, this validates Tesla quality control in making a CHAdeMO adaptor which has been used daily to pass >6MW through to the car over that time. Very impressed. Makes me more confident to buy this adaptor.
    To the OP, looking forward to the Tesla reply with slight interest. But honestly, our 2013 Tesla S85 only charges at 88kW maximum due to the limitation of the original "A" battery pack, and we haven't found the savings of a few minutes of charging per stop every two hours on road trips we could theoretically get with a newer pack to be of any big concern.
    • Informative x 5
  4. NYCR160
    NYCR160 Member
    Mansfield, CT
    Could this be a launch counter issue and not have any relationship to DC fast charge. Given that this is a 2015 P90DL and from the OP, “The Tesla tech told me that it was communicated many times to Tesla owners” …
    My guess is that there is communication error here. My fear would be that the SC is really saying you hit the limit on your launch counter and now we have to limit your charging rate.
  5. No2DinosaurFuel
    No2DinosaurFuel Active Member
    San Diego, California
    Or this could be tesla's new way of getting people to stop supercharging. We really don't know the motive and until we have actual data or some official statement, we can't come to any conclusion. Like others have said, there are examples of people supercharging all the time and seeing no major effect on the supercharging rate.
    But then this might be what tesla is saying because of the huge problems they are having at the supercharging stations and the major issues of slow supercharging.
    Personally I have not seen anything critical on my car, and all seems normal. But I can't really tell because of all the slow supercharging issues popping up.
    At the end of the day, all we customer ask of tesla is to shorten our wait time at the supercharging stations and right now, they are not really do a good job of it.
  6. Naonak
    Naonak Member
    Kansas
    I just got off the phone with upper management over this issue. I have some mental processing to do... I am on mobile right now, but as soon as I am at a computer I will post my RO that confirms what I said here.
    That's not to say the technicians are wrong, but between the phone call and the detail on the RO, my worst fears are confirmed. If anyone has access to the Tesla technical blog, this issue is apparently up there and describes the counter.
    The manager I talked to said he couldn't cut and paste it, but would put the gist of it in the RO. But if someone else has access that would be willing to cut and paste, that would be awesome.
    Bottom line, there is a new counter that will permanently restrict your charge speeds once you exceed a fast charge threshold count. I want this info to be wrong and if someone can disprove it, via official statement otherwise, great.
    But right now, the official word out of Tesla is that the car is operating as designed and it has passed a counter threshold for fast charging and is permanently restricted.
    RO will be posted in a couple hours when I get to a computer.
    • Informative x 11
  7. SomeJoe7777
    SomeJoe7777 Marginally-Known Member
    Houston, TX
    As was noted earlier in the thread, the ideal everyday charge rate for the Lithium-Ion chemistry is about 0.8C. On a 90kWh battery this corresponds to a charge rate of about 72 kW.
    72 kW exceeds the maximum rate that Chademo can put out (50 kW), and a lot of Chademo stations can't reach 50 kW anyway (or sustain it very long even if they can). 50 kW charging rates in my opinion are not at all harmful to the Tesla battery.
    Max regen in the Tesla frequently exceeds 60 kW, and certainly that isn't supposed to be harmful for the battery.
    • Informative x 11
  8. Johann Koeber
    Johann Koeber Active Member
    Hersbruck, Germany
    Just one data point:
    My P85 is little over 3 years old now and was driven close to 150,000 miles. The battery degraded about 7 %. Today I supercharged (as I do several times a week, given my mileage): It started at 114 kW, as the battery filled it throttled down to about 20 kW as the battery was over 90 % full and I unplugged and left.
    So no, Tesla did not dial down the power I am seeing at the SC. Sometimes when the battery is cold though, the power is reduced until the battery heats up.
    • Informative x 3
    • Helpful x 2
  9. Naonak
    Naonak Member
    Kansas
    I just want to point out they very specifically told me that my car has seen significant fast charging confirmed by the logs and is explicitly restricted from maximum rate fast charging going forward. The verbiage in the RO is very clear about it.
    • Informative x 6
  10. oktane
    oktane Active Member
    Shocking and I feel you are owed a new battery pack with restoration of your charging speeds. Counters are fine for internal QC but should not be used in a punitive fashion to save Tesla money on warranty claims. They charge waaaay too much for the car already.
    • Like x 7
    • Disagree x 2
  11. Naonak
    Naonak Member
    Kansas
    Here is text from the RO:
    I will share the actual RO with a mod or trusted member, I just don't want to post it unredacted with my personal info. I will post the redacted version when I get home.
    • Informative x 16
    • Helpful x 3
  12. SageBrush
    SageBrush REJECT Fascism
    New Mexico
    Are there additional derate points as DC charges accrue ?
    • Helpful x 3
  13. TexasEV
    TexasEV Well-Known Member
    Austin, TX
    As this is new to all of us, and hasn't happened on older cars that supercharge constantly (like Tesloop) I wonder if this is just for the newer battery chemistry. How old is your car and what battery size do you have?
  14. gabeincal
    gabeincal HODLer / Theta seller
    SF Bay, CA
    OP drives a 2015 P90DL
  15. thegruf
    thegruf Active Member
    indeterminate
    #55 thegruf, May 4, 2017
    Well I for one have a Tesla-Semi load of questions about the uncovering of this new charging information/parameterisation.
    In summary without even starting to list them is my guess is that
    all of us will want to know what the parameters are that affect charging and to what extent, so that we can make informed decisions as to how to ensure the optimum care and longeivity of our vehicles, and further how we can identify the status of these parameters when sourcing a used vehicle.
    I for one would not wish to go and buy a used P100D only to find out that the power is restricted and the charge rate is restricted because the previous owner had quite legitimately but unknowingly used up a good chunk of the goodness.
    • Like x 8
    • Love x 3
    • Informative x 2
  16. thefortunes
    thefortunes Active Member
    Wisconsin
    Another data point to note here - the OP charges exclusively via CHAdeMO. Others who have posted not having reduced rates (like my brother with over 120k miles of supercharging) have used Tesla SuC. Shouldn't matter, but who knows?
  17. EV-lutioin
    EV-lutioin Active Member
    In my experience Tesla Service Center personnel know less about their cars than the owners. They are probably not lying.... just clueless.
    • Like x 4
  18. CSFTN
    CSFTN Member
    Memphis, TN
    #58 CSFTN, May 4, 2017
    So, anyone other than OP can report with any validity of this restriction? NOT TRYING TO START A FLAME WAR -- I can't help but recall that *someguy* who posted in another thread that he/she goes out of his way to charge on free Chademos almost every day ... and then ridiculed another user when they suggested he was freeloading. Posted something like "why should I pay to charge at home when I can charge for free elsewhere?" Kansas City, right? {edit: here's the post Forbes says CHAdeMO is bigger and better than Supercharger network....}
    I do wonder if there's more to it than number of kWh in DCFC or even the frequency of DCFC. Maybe he made his bed, and Tesla specifically wrote a limiter to deal with people they felt were abusing free DCFC, in order to encourage them to charge at home? Maybe they even include in their algorithm if you do have access to AC charging at your home or place of work? Would that be wrong?
  19. Skipdd
    Skipdd Supporting Member
    Silver Spring, MD
    I have a couple of concerns and thoughts
    1) I bought and regularly use a Chademo adapter because until Tesla's recently announced plan/policy SuCs were supposed to be used for long distance trips not for commuting. In the DC area it is common to live in MD and work in VA and vice-versa. Some days, I also drive to many other parts of the DMV. On these days using Chademo based service (EvGo), is the only practical solution. I am nowhere near OP's total, but if there is any threshold, I want to know what it is
    2)Agree with other poster that this is now a required piece of info on any CPO car
    3)In general, I think Tesla needs to disclose any internal threshold limiters, so a buyer/owner can make informed decisions
    4)This reinforces my view around not counting on owning the car for an extended timeframe (5+ years) with high mileage. I'm not mad about this - to some extent it's expected as it's still leading edge technology. But, again it informs acquisition decisions (purchase vs lease for example)
    I will be interested to see how this evolves over the next few days/weeks.
  20. Electroman
    Electroman Supporting Member
    TX
    I am glad Tesla is doing this to protect the battery.
    The alternative is of course to reduce SC charging to 90 kW to everyone. You see, Tesla never guaranteed that their SCs will give 120 kW output. To protect the battery, reduce the charge to those that exceeded fast charging beyond a limit, or they could simply reduce it for everyone.
    Then OP would have no issues.
    • Disagree x 18
