I thought they capped the AC charging at 19kW on the current generation even if the voltage goes past 240v. (They reduce the amperage.)
That doesn't make much sense -- and the charge rate for most of a Chademo session on today's equipment with today's batteries is a lot lower than 50kW, more like 30-40kW. An HPWC on 277V 3-phase is 22kW...
No, the degradation that would happen from too frequent charges to 100% (and worse, leaving it there) is a decrease in capacity, meaning range. The cars that have max supercharger power decreased is to avoid similar damage to the battery, not the result of it.No time to go through this whole thread but I'm wondering if degraded mode is due to charging to 100% every time. I got a warning about possible battery degradation the first time I charged to 100% and left it plugged in (240 volt at home). I set it to 80-90% and no more warning.
To add to what TexasEV said, charging to 100% and driving the car within an hour or two of it finishing charge doesn't harm the battery according to a whole bunch of user experience over a couple of years documented in several other threads (all the fine print there is because I don't have definitive scientific proof!!!No time to go through this whole thread but I'm wondering if degraded mode is due to charging to 100% every time. I got a warning about possible battery degradation the first time I charged to 100% and left it plugged in (240 volt at home). I set it to 80-90% and no more warning.
The way the CHAdeMO protocol works is after establishing the handshake, the vehicle sends the current it wants to charge at every 0.1 seconds through the CAN bus. The charger then supplies the requested current. The vehicle uses that to control the taper.Has anyone spent the time studying the Chademo protocol, does it have 2 way negotiation in regards to the taper, or only instantaneous volts/amps? In other words, is Chademo a first generation DCFC protocol without a lot of built in granularity, and could that lack of granularity combined with daily use for a year and 30+K mile plus (maybe) silicone anodes be the problem here? Remove any 1 of these factors, and the battery is fine? As Bjorn has been mentioned as a data point, does he use Chademo (never,occasionally,frequently)?
I don't think there is any evidence Tesla is using pulse charging. But given the frequency required for pulse charging (in kHz or MHz), CHAdeMO obviously would not support it unless it offered a special mode for it.Furthermore, anyone know if the various DCFC charge protocols are pretty much apply a constant voltage at a constant and later tapering amperage and thereby charge the battery or in contrast is there a pulsing effect? If there is a pulsing effect, does that effect vary from Chademo to Supercharger to CCS?
It actually is dishonest to a degree. If for no other reason than we have a slider and are advised to not charge to 100% regularly. There's even a pop-up in the car if you do it too often. Why is that there? It's because it degrades the battery if you do it too often.
Close but not quite. Not just prototypes, when I bought my Model S in 2013 it had the two settings, daily (93%) and trip (100%). The slider was introduced with a firmware update I think in 2014. It's because EPA would determine range by averaging the two settings (that's what they did in the early Leaf). By having a slider rather than two settings the EPA uses the range at 100% charge.My understanding is this isn't quite the whole picture.
Very early prototype cars had a "range mode" and a "standard mode". By switching this out for a slider, there were some technical loopholes in ZEV credits.
(Personally I wish there were two distinct modes, as I've forgotten to reset the slider from 100% on the odd occasion I've needed it, only to then let the car sit far too charged the next day)
Right. The change was because of the EPA's idiotic rule about averaging two setting. The Leaf unfortunately did not have the software flexibility to be able to switch to a slider, so their only choice was to eliminate the 80% charge mode in the US order to be rated for the full range by the EPA.Close but not quite. Not just prototypes, when I bought my Model S in 2013 it had the two settings, daily (93%) and trip (100%). The slider was introduced with a firmware update I think in 2014. It's because EPA would determine range by averaging the two settings (that's what they did in the early Leaf). By having a slider rather than two settings the EPA uses the range at 100% charge.
I have personally charged my 2014 on this 80A@277V HPWC - 100 Innovative Way | Nashua, NH | Electric Car Charging Station | PlugShareAccording to Tony Williams' testing, at least the original dual chargers were firmware limited to 10kW, so you could draw 40A up to 250V and 36A at 277V.
So you're right, you can only slightly exceed the nominal 19kW by using a single leg of a 480/3ph service: you'll get 20kW, not the 22kW I said above.
I can't imagine that Telsa has ever guaranteed a particular charge rate. Especially since we know that will all depend on a number of factors.
Nothing you just said proves anything, just as Tesla never guaranteed any specific charge rate. "Up to" x miles "in as little as" y minutes doesn't mean that's what you will get-- it's the best possible result in ideal circumstances.
I think most people would agree that they don't want Tesla making these sorts of changes without their knowledge and permission. Our vehicles were not artificially limited when we purchased them, only after a period of ownership. That should have been disclosed prior to purchase, clearly. If batteries are subject to premature failure if charged at the high rate of speed advertised by Tesla, then Tesla needs to cover such failures under its warranty, and if necessary, extend the warranty coverage.Nothing you just said proves anything, just as Tesla never guaranteed any specific charge rate. "Up to" x miles "in as little as" y minutes doesn't mean that's what you will get-- it's the best possible result in ideal circumstances.
