I spent a day at Carolina Motorsports Park (CMP) in SC doing an HPDE open track event. Was point to pass, but otherwise open (no run groups). I know there are several performance threads out there, but here's my take on going to a relatively isolated track.
I didn't want to drive 40+ miles each way to the closest supercharger during the event (would have been nearly three hours if I had to charge from 0-100% and return and then I'd still be down 40-50 miles). I ended up using my mobile charger in a 14-50 outlet and got about 30mi/hr range (32 amps). I think I put in about 170mi of range for entire event. I ended up getting 4 decent (15+minute) sessions. I probably could have gotten a fifth had I showed up an hour earlier. By the fourth session I was well under %50 SOC and it was pretty obvious the acceleration was way down.
I think to max out time on track I would now go out for first session and just tool around and practice braking points, turn in and carrying speed and just feather accelerator for the whole session. Get the tires scrubbed, learn track, etc. Then remaining sessions run light for the first 2 laps, give it 2-3 hard laps and then a cool down (maybe another lap or two), but just try for 2-3 HARD laps when you've got your rhythm down. I would also probably come in early if it was a 20 min session and get charging asap. I had to leave 70ish miles in the battery to safely make it back to SC and you arrive at track 50 miles range down, so the actual range/SOC window is something like 70-240 miles range window (only 130 miles to use). It is critical to get to track early (like at least and hour before everyone else) to try to top up as much as possible.
