mpgxsvcd
The Tesla engineers just stated that they won't do a tri motor Model 3 because the motors would be "hard to fit" in the Jay Leno video.
That is max discharge value. The car can't hit those numbers. Those are just theoretical maximums. I have seen 629 Hp as a max discharge value but the car itself can only output about 600 HP in real time under optimal conditions. Typically my max discharge values are well below 600 HP and actual values are much less. Those are also values at the battery. There are a lot of losses through the motors and then to the wheels.Are we talking wheels or motor?
Because WUGZ canbus data showed 447hp for the non-boost LR AWD, and 497 with acceleration boost... (and 580 on the P)
Remember, in an EV power in the battery is like power in the gas of an ICE vehicle. Power at the battery is not power at the motor. There are losses between the two.
Wugz said:Peak power increased from 333.2 kW (447 HP) to 370.9 kW (497 HP), an increase of 50 HP (+11.3%)
Peak torque increased from 501.75 Nm to 564 Nm, an increase of 62 Nm (+12.4%)
Front motor peak power increased from 139.5 kW to 175.5 kW (+25.8%) and peak torque increased from 185.5 Nm to 232.25 Nm (+25.2%)
Rear motor peak power decreased from 231 kW to 221 kW (-4.3%) while peak torque increased from 318.5 Nm to 333 Nm (+4.5%)
WUGZ said:The majority of the increase is due to increased front motor power and torque, with the rear motor actually generating slightly less power overall for a more balanced power delivery to all four wheels.
Last little unofficial china leak I saw was that they were shooting for simultaneous release with production ramping in March in both Fremont and Shanghai for 2Q release. With that said, I won't be surprised if Fremont needs more time.If you order a Model 3 LR right now the US website says to expect delivery in May of this year. I am having a hard time believing that if I ordered a Model 3 LR today and a Model 3 Ludicrous the day it is announced that I would get the Model 3 Ludicrous before the Model 3 LR. I believe they will announce the Model 3 Ludicrous soon but I don't think deliveries will start for many months.
I know no one in the US wants to hear this but I also think this is going to be announced as a MIC car for Europe and Asia first. I think the US based cars won't get announced till 3-6 months later and won't ship here until closer to the end of the year as a 2025 model. Just a hunch though. Could be totally wrong on this for sure.
This is a quick and dirty power curve I was able to generate of a model X LRThe Refresh 2021-2024 Model S LR has 3D1 in the back and 3D8 in the front. The 3D8 is a bit of a mystery, but from all I can see it is a slightly modified 3D1.
Or it's geared way longer and it has the same power at rpm curve.This is a quick and dirty power curve I was able to generate of a model X LR
And an attempt to work backwards to RPM since the gear ratios are different and the X has different diameter front and rear tires
I suspect the front motor is being limited pretty significantly at lower speeds
The second curve should be normalized for gearing. It's making much less power until ~7000 RPMOr it's geared way longer and it has the same power at rpm curve.
So he is stating real time battery numbers there. That is fine but the actual numbers at the motor and at the wheels are significantly less. If the motors were producing 500 HP in the Model 3 LR with Boost then the vehicle would be way quicker than it is. 0-60 mph with 500 HP would be closer to 3.4 seconds or less. With 450 HP 3.7 sounds about right. 4.2 is reasonable for right at 400 HP.Not sure I understand you... those were observed on the canbus as live numbers when doing a floored run in the car, not theoretical ones.
In fact you, specifically, discussed these #s with me almost 1.5 years ago here:
670hp Model 3? Possible?
MotorMatchup says 514 HP and 516 LB FT torque and they get identical times from the 60’ time to 1/4 mile with what I consistently get at the track. However, they are using the vehicle weight without driver I believe. If you factored in the extra 200 lbs for the driver I think that the realistic...teslamotorsclub.com
I understand there's drivetrain losses-- I specifically point that out in asking if you were talking wheel or motor numbers because there's loss in between.
https://www.reddit.com/r/teslamotors/comments/eczol8/model_3_awd_acceleration_boost_tested_from_0160
and
Well, here's the thing...........peak numbers for the P as I stated above are 520/650 at the wheels. However, these cars ramp in the power from 0-40 MPH, and depending on the curve of that ramp, acceleration can vary quite a bit between the LR, LR AB, and P, all with the same battery and motors. The Plaid does the same thing, power is ramped in from 0-70 MPH, then HP is maintained as torque drops with RPM. Peak horsepower doesn't tell the whole story.So he is stating real time battery numbers there. That is fine but the actual numbers at the motor and at the wheels are significantly less. If the motors were producing 500 HP in the Model 3 LR with Boost then the vehicle would be way quicker than it is. 0-60 mph with 500 HP would be closer to 3.4 seconds or less. With 450 HP 3.7 sounds about right. 4.2 is reasonable for right at 400 HP.
Highly doubt they’re doing 275 squareLooks like 275/30/r20, at least in the rear. Hopefully square.
18s too if they clear the brakes.Please have a 19” rim option. 20” rims on a sedan are *ridiculous*
Tesla already does this with the Model 3 and Model S with their track packs.Tesla should play the optional equipment game that all the others do and offer race tires and brakes as a dealer/factory add on to set fast laps.
Too wishful of thinking for me18s too if they clear the brakes.
According to this he says ~2.2 tons which is about 4500 not sure how accurate he is though.I believe the Hyundai Ioniq 5N will be closer to 4,900 lbs when they officially release the specs for it.View attachment 1024155
