Racerx22b
@unplggdd on Instagram
The beginning of the end of common sense and decency and civilized behavior, in action.
Remember we don't have any moral authority to point fingers at ICE cars when they park... because they have every right to park wherever they want, unless the sign board says otherwise.
No, you're wrong. Short of having perhaps the world's most complicated flow sheet posted at each pubic charger explaining who gets priority over who and then having some magical way to prove someone is following this massively complicated flow sheet there is only one way to maintain order. First come, first serve. Or... DO NOT touch another person's vehicle while charging. Those are the only rules that can be universally followed and enforced.
However, if you pull up to a public charger and I'm nearby and you want to politely approach me and plead your case for why you have priority over me to use the charger I will give you the courtesy of hearing you out. If you have a good case I will move my car and allow you to take my place. In this case, you give ME the option to use use common sense and demonstrate civilized behavior. Unplugging me and assuming your needs are greater than mine is not using common sense and is not being civilized my friend. You're just being a colossal JERK OFF.
