It's not an electrical system we are cycling, it's a chemical system.
Heat x time are the two key factors and you can find some things out by increasing heat and hoping its the same as a lower heat x a longer time but you can't increase time and sometimes time is the difference maker.
For a purely unrelated example leaf or piece of paper ages differently at different temps but you can't simulate 10 years in a day by making it 3650 times hotter because it'll catch fire and that isn't aging, not even close to the same result. Even getting it close to ~451F changes the nature of the situation too much to allow any huge amount of time compression.
Similar things with battery chemistry. Heat and time interact but you can't simulate everything without just waiting. You can do hot box tests but they only predict a trend and that prediction can be wildly inaccurate.
I would second this situation.
Batteries going through cycles endure some level of Lithium-Ion plating. Ions that get attached to anode and cathode and become immovable. Lithium Battery Research: Plating and https://www.sciencedaily.com/releases/2014/09/140903105638.htm
This causes some increases in IR (Internal Resistance).
Higher levels of IR cause higher levels of heating in the battery during charge cycles that are continuous at near or over 1C charge rates. Plating also happens at cold conditions. This is why Tesla does not allow high-speed charging in the winter until the battery core is warmed.
So, I could say that the OP is possibly saying older chemistry NCA batteries used may have seen some degradation over 500 cycles that the Ion Plating causing some concerns to limit the charging speed at SuperCharger sites due to the extra heating caused during full power charging. But Tesla would definitely have to clarify this and if they did put out a public notice, it could hurt the stock price, company view by the public and demand profile of new purchases. Even if they said "we made it better, so no worries" it just indicates they took a chance with the early Panasonic cells just to get things rolling in the earlier years.
However, this doesn't mean Tesla is slower-charging older battery packs. Maybe they taper earlier in some cases if the core temperature is rising too fast or they sense higher ambient air temps outside? I wouldn't want to force a faster charge under hot conditions (outside the proper healthy operating temperature range of the cells).
As dhanson856 states - this is a chemical reaction process, not just a battery. People should realize that it is far more complicated than is implied by the "plug and play" nature of EV ownership. One day, batteries may be more hardened without these idiosyncracies. Without the parasitic nature of Ion Plating, batteries could last nearly "forever". Well, at least 5000 cycles would be nice. Some LTO batteries now offer far more, as do some LiFEPO4 products (8000 cycles with 80% capacity remaining).
Most data is also available from Jeff Dahn, now associated with Tesla. Many here have watched his video(s).
Why do lithium-ion batteries die? (long)
