DJRas
Exactly my situation.Adding myself to the list of affected owners on a 85kWh pack. Went from 6% degradation to 17% right after the software update. Finally got to a service center and the tech said it's because of high supercharger usage, and it's something that Tesla implemented to protect the battery. I drive a lot and the lower range creates more of a need for me to charge more frequently, and supercharging is convenient for me as I'm commuting to/from work.
My concern (on top of the fact they did this with no communication and no plan for resolution), is that they may decide to degrade the battery again to "protect" it, and my car become essentially useless given my driving patterns, which is the entire reason I bought the car in the first place.
I also wonder how this factors into the "unlimited" battery warranty, since a battery with significantly lower range than the rest of the fleet is no longer performing as expected and should be replaced?
I would expect that they believe your battery was closer to 12 percent degraded prior to the update and that you are closer to 23% now.
I also now MUST supercharge twice per day for my commute and trips i used to make without needing to Supercharge i now must.
That they hide the usable kWh and adjust the conversion factor at whim to further obfuscate the actual degradation is not right.
If they did this to protect from fire because they detected some anomaly in our packs then NHTSA needs to investigate.
