sorka
Why don’t you guys start a thread on Teslas own forum then and monitor it’s „survival“
No need to speculate. I stopped posting there years ago because threads mysteriously vanished.
I bet they failed to mention that you MUST surrender your current battery for the replacement.UPDATE:
They also did verify that I COULD buy a replacement battery (for about $20,000 installed).
Until they need to do it again.The engineer stated that there will be no further reductions to the charging of the vehicle however, this shift is a permanent change.
The problem is your 97% now is probably below the true 90% and takes much longer to charge to that range.They said... with my now being REQUIRED to SuC twice per day for my commute that I would likely qualify soon.
Also hinted that "stressing the battery" might accelerate that too.
So... Jack-Rabbit starts and charging to 97% seem to be in my future.
Is the Tesla BMS able to isolate strings of cells? Looks like the organization is 74 in parallel, then 6 in serial within a module - if you knock out a string, you reduce the maximum voltage by 4.2 volts, but if that lets you increase the maximum voltage per cell from, say, 4.15 to 4.2, you come out ahead. (But, that requires being able to isolate strings.)I’d posit that it’s an all-or-nothing deal. They can’t restrict the max voltage on some modules or groups of cells because that would cause the pack to be grossly unbalanced.
The 295 multiplier is related to USABLE... NOT nominal.The pack value in TM-Spy is the same as the nominal full pack value in Scan My Tesla. So @DJRas TM-Spy data would show this same thing, i.e., his rated miles x .295 would equal his TM-Spy pack voltage. And there is no question that his car has been affected.
All of the range loss occurred with 16.2. The later ones have been adjust charging algorithms and will likely REDUCE the chance of damaging your battery.I’m still on 2019.16.2 and refusing updates because I don’t want to lose range, especially since my range already sucks at 187k miles I can barely get 165 real world miles on a 100% charge. Can anyone suggest a canbus reader I can get off of amazon and point me to a cheat sheet on how to use it and what to look for? I want to be able to provide data here especially given that I’m one of the higher mileage early build cars.
No, they DID say that... "core charge". Tesla will then "recondition" the old pack and recycle defective modules.I bet they failed to mention that you MUST surrender your current battery for the replacement.
ScanMyTesla data shows Rated miles and SOC which match you dash displayed numbers.Your own numbers say different: Nominal full pack = 64.3 kWh. Rated miles = 218. Then, 64.3/218 = .295.
All the scan my tesla data I have seen shows the same calculation.
They won’t let you keep it. Exchange or nothing. weather your paying for it or it’s warranty. Doesn’t matter. Now you may have legal case to keep your old battery if they forget to tell you they keep it as a core.So what was the core charge if you wanted to keep your old pack?
UPDATE:
I just finished having my battery tested at Oceanside Service Center.
As expected they said that my battery does not fit the criteria for replacement.
The test is HV Battery Capacity (looking at Charge Amperage Capacity?).
My battery is version 41 (41 is the number they used... but they didn't call it version).
Original rated range for this pack was 264 miles at 295Wh/mi (77.88 kWh usable capacity).
A battery with my age/mileage should have a capacity of 231 miles (Fleet-wide average).
IF my battery is <90% of that window they can replace my battery under warranty.
With my 217 mile rated range that is 93.9% therefore... no warranty replacement.
BUT, the currently reported 217 mile rated range is NOW based on 276 Wh/mi (Which they saw while looking at my recent drives).
IF we use the 295 Wh/mi calculation for rated range my current max range is 204 miles - 88.3% of nominal.
ALSO, with rev 2019.20.2.1 the most I can charge to is 97% or 210 miles (@276 Wh/mi) thus 90.9% of nominal.
At 295 Wh/mi my 97% range is only 196 miles or 85% of nominal.
I will be returning this afternoon to discuss this information with the technician
Additionally, The official Tesla stance is "These changes are meant to increase battery longevity. NOT related to the fires".
When confronted with my stance that they are software degrading MY battery to keep it from degrading on its own...
They said "yeah... that seems wrong" and "Tesla will likely look closed at the new data they gather after this update and will "likely" revise the algorithm and POSSIBLY restore some of our range to those of us affected
Also, my battery reported a BMS error "Battery_Brick_Limited (hidden)". They did not explain that well. Just that it was "not critical to battery usage" and "NOT covered under warranty"
The Service Manager and the Technician really seemed to care about my concerns and they WANT to replace my battery. But until they can go to engineering with an "Out of normal condition" their hands are tied.
Oh Yeah!!! while I was there they replaced my recalled air bag!
I think there are 5 years of charging habits that ultimately lead that "sudden loss"
I think that the sudden loss is essentially a diagnoses of and treatment for a problem that developed gradually over time.
Maybe they (Telsa) are just doing their best to protect consumers and keep batteries safe in spite of some possible misuse and degradation.
I see your point and I apologize for using the word "misuse". Maybe I could have said:So, when there no evidence that Tesla itself is pointing to any misuse of the batteries by the owners, why should you?
