Only during charging it was up to 4.3V. Not after finishing the charging.
Did you notice the charging voltage change when you were capped? Or just the final voltage after charging was completed?Do you have data from that? I have CAN bus data from my car since 2016 and I have never seen the cell voltage go above 4.2. Even before I had CAN bus access, the car used to show the battery voltage on the charge screen during supercharging and it never ever went above 403 Volt which is just under 4.2 per cell (96 bricks in series). If you have data showing it above 4.2 Volt per cell I'd be very surprised.
That's not how you charge a Li-Ion cell. During the initial, constant current (CC) charge phase, you apply <4.2V (typ 3.5V for a dead cell), but don't exceed the max charge rate. As the cell's state of charge increases, you increase the voltage applied until it hits 4.2V, at which point you switch to constant voltage (CV), allowing the charge current to trail off until it drops to the full charge cutoff.So, applying 4.3V to the cells to charge faster, but not exceeding an actual cell voltage of 4.2V was a normal pre-2019.16 practice?
Perhaps used batteries that are only at 4.18V or 4.19V aren’t “microcapped”, but just can’t reach 4.20V without being charged at a slightly higher voltage such as 4.225V due to their internal resistance?
The specsheet for the Panasonic NCR-18650B shows a CC current of 0.3C (975mA on a 3.25Ah cell), a Vmax of 4.2V, and a charge current cuttoff (full charge) of 65mA. At those rates, the CC phase is ~3 hours, and CV phase is another hour.
You NEVER go beyond 4.2V. Bad things® happen if you do.
I'm on Firmware 8.1. I have been a Tesla owner since 2013, and my first was car #9846. 4.2 is the highest. Rarely, you may see 4.21 and those two only during charging. At charging completion, it will drop to 4.19-4.195Thanks for the explanation! As I said, I have no pic from that, it's only from my memory. So maybe wrong remembering. Thats why I asked if someone with firmware before May 2019 can check it.
Bought the car in November 2018. Did my first trials with ScanMyTesla. Was happy until April 2019 and then my battery died. After getting back the car in June I started to document with screenshots, but since then I never saw it again.
Thanks a lot!I'm on Firmware 8.1. I have been a Tesla owner since 2013, and my first was car #9846. 4.2 is the highest. Rarely, you may see 4.21 and those two only during charging. At charging completion, it will drop to 4.19-4.195
They're letting more more cats out of the bag
Thanks for the help.Hello Adrian,
I had the same issue after getting my battery exchanged. After some discussions with my SC and sending them the attached picture they have uncapped my battery to the typical 365km range. Good luck !
Any luck with Tesla?Thanks for the help.
I will try to get my battery uncapped. I call SC and keep you posted.
Thank you.
I managed to get a response from service center after creating a appointment from the app.Any luck with Tesla?
May I ask you to go to a supercharger with a warm battery and charge to 100% and check the charging power in kW and also the min and max voltages of your cells if you are close to 100% ?I'm on Firmware 8.1. I have been a Tesla owner since 2013, and my first was car #9846. 4.2 is the highest. Rarely, you may see 4.21 and those two only during charging. At charging completion, it will drop to 4.19-4.195
Saw this stuck on all the local super charger today hah!
Looks like it won’t last long unfortunately from the weather.
That is a brilliant move. If whoever did this is here, post the file. If not, we should do it ourselves and post these to every stall every time we supercharge. If the paper is completely stuck on by clear packing tape it should be perfectly weather proof and hard to remove.
Bravo!
You can't charge any further once a cell group hits 4.2V. All the groups are wired in series. The charge current flows through all of them. Once one is full, you're done. There's no way to continure to charge the other 95 cell groups without overcharging the fullest and risking fire.May I ask you to go to a supercharger with a warm battery and charge to 100% and check the charging power in kW and also the min and max voltages of your cells if you are close to 100% ?
My car is on this level only charging with 0...1kW and if the first cell reaches 4.201V the charging stops. After the stop the voltages on this cell falls quickly to 4.19 V and because of imbalance some other cells are in 4.13V. No more trial to get closer to 4.200V on the cells. With your software I remember some kind of pumping to really reach the full charge and also never less than 2...3kW charging power. I agree that the actual way of charging is much better for long life and preventing overcharging but it means a lost of around 10km. Its technically acceptable but sad to have to do such kind of guessing because of no clear statement from Tesla...
